I am currently working on use the arduino R3 with a RS422 sheild to control Mdrive motor. I use the "Serial.write("SL 51200^M")" commands in order to get the motor rotate but it didn't work. The motor accepts ASCII commands.I think the command don't pass the port to the motor but I don't know how to set up the code. Pls help me about it .
ufo135792:
I've tried it but it doesn't work either. I think the commands just run pass the Arduino board not the rs485 shied but I'm not really sure..
Your first post said you had a RS-424 shield, This post says you have a RS-485 shield. They are not the same. Which it it and post a link to the board specifications?
