Serial Output in setup not working
if I try to put an Serial-Output inside the setup, it's not working.
#include <WiFi.h>
  Serial.begin(115200); // Set up Serial Monitor
  WiFi.mode(WIFI_STA);  // Set ESP32 as a Wi-Fi Station
  Serial.print("MAC-Address: ");
  Serial.println(WiFi.macAddress()); // Show MAC-Address
void loop() {/*...*/}
Any idea? There's nothing in the serial-monitor!
Best
Erik
You are not giving the board much time to initialise the Serial interface before trying to use it
Start by adding a delay() of 500 milliseconds after the Serial.begin()
Or, rather than an arbitrary delay, wait until it is ready:
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB
As shown here:
Shouldn’t the board be ready when it returns from begin()
(The issue might be more on the computer side?)
@EriksArduino hasn't said what board it is; in particular, whether it has native USB
I'm using a Arduino-Nano-ESP32
A great idea until you unplug the USB and power the board from an external power supply
That board has native USB as far as I know; so try the suggestion in post #3.
There are ways around that. One also has to be careful when it's first connected to external power and USB and later USB is disconnected; on at least the 32U4 based boards, that can bring your board to a near grinding halt if one keeps on printing to Serial. OP needs to test that if it's a requirement.
I know, but don't let's make things any more complicated than it needs to be. Adding a delay() after the begin() is a quick and dirty way of identifying the problem before deciding the the most appropriate solution based on requirements
Thanks a lot! That works!
Best
Erik
:nerd_face:
Note the warnings from @UKHeliBob that your code now relies upon that USB connection being active at startup, and remaining active...
