I'm using an Arduino Uno for some simple serial communications with a device using AT commands.
After coding what i wanted to do and uploading, i tested it out in serial monitor and everything worked ok.
However, when i connected the serial device nothing was happening. I connected the Uno Tx and Rx pins to a comm port on my computer and the output was all garbled like the baud rate was wrong. I checked again in serial monitor and everything looked ok there.
So as a test i wrote a very basic program to write Testing!!! to the serial output at a baud rate of 38400.
Serial.begin(38400);
Serial.println("Testing!!!");
You can see in the attached screenshot that the serial monitor in the IDE displays the correct output. My putty session on the Uno's output is garbled.
I've tried multiple baud rates and with the uno powered from it's DC jack (no usb connected). I'm not sure what I may be missing here.
Did you connect the grounds? You need to connect the grounds as well as Tx/Rx for serial communication to work.
(also, the serial port has to be TTL, not RS232 voltage levels (or you need RS232 to TTL converter, ex MAX232) - I don't know if this is the case with all computer serial ports)
Yes. To connect an Arduino to a 'real' rs232 serial port, you'll need an rs232 level converter, or at least some form of signal inversion. (theoretically, a "1" on rs232 is -3V (or less) and a 0 is +3V (or more), but there's been a lot of cheating "recently", and 0V/5V "rs232" is pretty common.)
westfw:
Thanks,
I picked up a MAX232 IC this morning and now it's all good.
