There are commercial products that load a driver on your PC to give a virtual serial port. Data sent to that port gets piped over ethernet to a translator box with a serial output. In theory the Arduino IDE should be able to use the remote serial port as if it were local. Is this likely to work in practice?
mikb55:
does it have DTR for auto reset?
It's possible. Some "serial servers" have assorted modem control settings, and one that asserts DTR when the connection becomes active (just like on a local serial port, allowing the original auto-reset to operate.)
There's also a telnet option to support twiddling the rs232 signals. I think that's less common, though.
We'd have to know the details of exactly what "translator box" and "PC-side driver" you're using, though.
People have written separate "over the air" upload programs for Arduinos with ESP8266s attached to the serial ports, I think. The Uno WiFi 2 is supposed to support this. (it doesn't necessarily have the "serial emulation" in the middle.)
As @westfw wrote, it is possible.
Years ago I worked with DECservers or MOXA Ethernet/RS232 transceivers (RS232 to TTL is needed due to different voltage levels!!!). Both are usable but any ethernet/RS232 transceiver should be usable (should have also DTR) and even ethernet/USB transceivers are on the market.
If I were to go shopping for a converter, what specs (apart from DTR support) are needed for something to work reliably with the Arduino bootloader?
Does latency matter? I saw one adaptor quoted at 2ms.
Latency shouldn't matter, because the upload protocol is very lock-step.
Besides, latency would tend to be dominated by the network.
Data transparency is important. Some converters have problems with newlines, nulls and/or 0xFF, especially if they run the "telnet" protocol. Running telnet is necessary if you want DTR manipulation during the connection (as opposed to just at the start.) But I don't think it should be necessary.
It does need to raise/lower DTR depending on connection status, not just provided it as a constantly ON signal...
but first consider software options for remote upload. for what board do you want to solve this?
Juraj:
Mostly the Mega2560 but sometimes the Mega328 as well. I'm ok with co-locating another micro to act a programmer if that is what's needed.
Not what the OP is asking for but I use usb over cat5e cabling to program my arduinos without removing them from where they are installed. .
A USB over Ethernet hub might work for your task. I have the Silex ds400u2 (SX-DS-4000U2) which I have on my workbench connected by Ethernet to my laptop across the room. I have a USB monitor, keyboard, mouse and Arduino all remotely connected to my desktop, which is easier than moving my laptop each time I'm at the workbench.
