Serial over usb & SPI output
Hi there
Is it possible to input serial to the arduino uno, over usb, then convert this to SPI so an SPI enabled device can function with it?
Any help would be appreciated.
Thanks
Jack
Did you try something simple like this:
// the sensor communicates using SPI, so include the library:
#include <SPI.h>
// pins used for the connection with the sensor
// the other you need are controlled by the SPI library):
const int chipSelectPin = 7;
  SPI.begin();
  pinMode(chipSelectPin, OUTPUT);
  uint8_t MOSIbyte, MISObyte;
  if (Serial.available() > 0)
    // take the chip select low to select:
    digitalWrite(chipSelectPin, LOW);
    // Loop till out of input so we don't de-select after every byte
    while (Serial.available() > 0)
      MOSIbyte = Serial.read();
      MISObyte = SPI.transfer(MOSIbyte);
      Serial.write(MISObyte);
    // take the chip select high to de-select:
    digitalWrite(chipSelectPin, HIGH);
I have tried your code, but nothing can be seen on the serial monitor!
I want to take in data through SPI ports and see that on serial monitor, I am using ADIS16210 sensor and Arduino UNO!
Please let em know your suggestions!!!
Thanks
You should start by reading the device's datasheet:
http://www.analog.com/static/imported-files/data_sheets/ADIS16210.pdf
You have to send commands to the device to read the values. The values are in binary. If you want something human-readable you will need to interpret the data some before printing the values to your serial monitor.
Hello John,
I have tried many things but couldn't get any data from the sensor and display it on the serial monitor. Need your serious guidance to resolve this issue asap. I am using the code below.
//Add the SPI library so we can communicate with the ADIS16210 sensor
#include <SPI.h>
//Assign the Chip Select signal to pin 10.
int CS=10;
//This is a list of some of the registers available on the ADIS16210.
//To learn more about these and the rest of the registers on the ADIS16210, read the datasheet!
#define BIT4		        0x0010
#define	FLASH_CNT		0x00	//	Diagnostics, flash write counter (16-bit binary)
#define	SUPPLY_OUT		0x02	//	Output, power supply
#define	XACCL_OUT		0x04	//	Output, x-axis acceleration
#define	YACCL_OUT		0x06	//	Output, y-axis acceleration
#define	ZACCL_OUT		0x08	//	Output, z-axis acceleration
#define	TEMP_OUT		0x0A	//	Output, internal temperature
#define	XINCL_OUT		0x0C	//	Output, ±180° x-axis inclination
#define	YINCL_OUT		0x0E	//	Output, ±180° y-axis inclination
#define	ZINCL_OUT		0x10	//	Output, ±180° z-axis inclination
#define	XACCL_NULL		0x12	//	Calibration, x-axis acceleration offset null
#define	YACCL_NULL		0x14	//	Calibration, y-axis acceleration offset null
#define	ZACCL_NULL		0x16	//	Calibration, z-axis acceleration offset null
#define	ALM_MAG_X		0x20	//	Alarm, x-axis amplitude threshold
#define	ALM_MAG_Y		0x22	//	Alarm, y-axis amplitude threshold
#define	ALM_MAG_Z		0x24	//	Alarm, z-axis amplitude threshold
#define	ALM_MAG_S		0x26	//	Alarm, system alarm threshold
#define	ALM_SMPL_X		0x28	//	Alarm, x-axis sample period
#define	ALM_SMPL_Y		0x2A	//	Alarm, y-axis sample period
#define	ALM_SMPL_Z		0x2C	//	Alarm, z-axis sample period
#define	ALM_CTRL		0x2E	//	Operation, alarm control
#define	GPIO_CTRL		0x32	//	Operation, general I/O configuration and data
#define	MSC_CTRL		0x34	//	Operation, orientation mode
#define	DIO_CTRL		0x36	//	Operation, digital I/O configuration and data
#define	AVG_CNT			0x38	//	Operation, decimation filter configuration
#define	SLP_CNT			0x3A	//	Operation, sleep count
#define	DIAG_STAT		0x3C	//	Diagnostics, system status register
#define	GLOB_CMD		0x3E	//	Operation, system command register
#define	LOT_ID1			0x52	//	Lot identification, Code 1
#define	LOT_ID2			0x54	//	Lot identification, Code 2
#define	PROD_ID			0x56	//	Production identification number
#define	SERIAL_NUM		0x58	//	Serial Number
  //Configure the SPI connection for the ADIS16210.
  //Initiate an SPI communication instance.
  SPI.begin();
  SPI.setDataMode(SPI_MODE3);
  SPI.setBitOrder(MSBFIRST);
  SPI.setClockDivider(SPI_CLOCK_DIV32);
  //Create a serial connection to display the data on the terminal.
  Serial.begin(9600); // send info to serial port
  Serial.println("Start ADIS16210 Accelorometer Sensor Demo....");
 // initialize ADIS16210
//    sensor_init();
    	while(1)
		// read sample from device and print to uart
		loop();
void sensor_init(void)
  	// set average count / sample rate to 1Hz (512Hz/(2^9)
	write_reg(AVG_CNT,0x09);
       	// data ready enabled on DIO1, busy indicator enabled on DIO2
	write_reg(DIO_CTRL,0x37);
void loop(void)
	short x_accl, y_accl, z_accl, serialID;
	// read accelaration
	x_accl = read_reg(XACCL_OUT);
	y_accl = read_reg(YACCL_OUT);
	z_accl = read_reg(ZACCL_OUT);
        serialID=read_reg(SERIAL_NUM);
Serial.print(x_accl);
Serial.print('\n');
void command(unsigned char val)
	// send command
	write_reg(GLOB_CMD,val);
void write_reg(unsigned char address, unsigned char value)
	digitalWrite(CS, LOW); // Enable sensor /CS           // lower !CS pin
	SPI.transfer(0x80 | 0x04);
	SPI.transfer(value);
	digitalWrite(CS, HIGH); // disable sensor /CS              // raise !CS pin
	delay(45);					  // stall time is 40us for ADIS16210
void write_reg_int(unsigned char address, unsigned short data)
	write_reg(address,data);
	write_reg(address+1,data>>8);
short int read_reg(unsigned char address)
	short int data;
	short int hi_byte, lo_byte;
	digitalWrite(CS, LOW);           // lower !CS pin
	// send address (1st two bytes)
	SPI.transfer(XACCL_OUT);
	SPI.transfer(0x00);
	delay(45);					  // stall time is 40us on adis16210 with normal mode
	// send dummy bytes for data
	hi_byte = SPI.transfer(0x00);
	lo_byte = SPI.transfer(0x00);
	digitalWrite(CS, HIGH);             // raise !CS pin
	data = (hi_byte << 8) | lo_byte;
	// return data read from device at 'address'
	//return data;
