Hello,
I am reading data from a bunch of xbees, checking and cleaning the data, then sending them off to another program (labview) to do stuff and things.
Labview will read and interpret the data great for a couple of hours to days, then all of a sudden I no longer read any data. That is until I hit the reset button on the arduino.
After some investigation I have a couple of ideas, but nothing seems to work yet. I have tried Serial.flush(), overflow, and stream.flush().
Am I overloading the buffer on the arduino? I send the data to labview immediately after it is checked and cleaned. I have no idea why my arduino is freezing.
Thank you.
Code is below, as well as uploaded
// Introduction //
// Libraries //
#include <SoftwareSerial.h>
// Variables //
// Xbee Variables //
int packageLength; // How large is the package incoming from the Xbee radios
int ID;
boolean proceed = true;
byte checkSumCalc = 0;
byte xbeeByte[30]; // Was 26, lets see if this works.
byte xbeeOut[36]; // For sending commands to gates
//byte discardSum = 0;
byte lengthMSB = 0;
byte lengthLSB = 0;
byte frameType = 0;
byte frameID = 0;
// Serial Available Variables //
byte addy5; // 1st byte of address information
byte addy6;
byte addy7;
byte addy8; // 4th byte of address information
byte save; // 0x0 = do not save until a 0x2 is read
byte port; // Which port/digital IO pin on the xbee to command
byte value; // Do you want it high(0x5)(off) or low(0x4)(on) because the arduino reads low as on. May need to change this
char pin; // this is a char produced from the port byte.
// Communications declarations //
const int XB_RX = 2; // XBee's RX (Din) pin *Different pins from Analog in
const int XB_TX = 3; // XBee's TX (Dout) pin
const int XBEE_BAUD = 9600; // Your XBee's baud (9600 is default)
const int SERIAL_BAUD = 19200; // Baud rate for computer communication (make sure it is same for "serial monitor"
SoftwareSerial xB(XB_RX, XB_TX);// Setting up the channels for communication with the zigbee via sparkfun redboard
// Setup //
// Setup is the beginning of the program to initialize all pins
// communications, and declarations. This will run only once.
Serial.begin(SERIAL_BAUD); // Sets the baud rate for communication via terminal monitor on computer
xB.begin(XBEE_BAUD); // Sets the baud rate for communication with the Coordinator receiving Xbee radio
// Loop //
// This loop will run continuously until batteries run out, or the sun dies.
// Here we will run a few subroutines. One will be to read the sonar, BV and PV.
// Another one will be to send out data through the zigbee radio.
if (xB.available()) {
xbeeByte[0] = (int)0;
xbAvailable();
proceed = true;
if (Serial.available()) {
serialAvailable();
if (xB.overflow()) {
Serial.println("Software serial overflow");
void xbAvailable() {
// This section prints out all xb bytes for diagnostics purposes
for (int i = 0; i < 35; i++) { // reset xbeeByte to 0 and = length to get checksum
xbeeByte[i] = xB.read();
Serial.print(xbeeByte[i]); Serial.print(",");
delay(1);
Serial.println("End of line biotch");
delay(10);
if (xB.available() >= 12 && proceed == true) { // If available # of bytes is greater than 21 proceed
proceed = false;
if ((xbeeByte[0] = xB.read()) == 0x7E) {
for (int i = 1; i < 3; i++) { // reset xbeeByte to 0 and = length to get checksum
delay(1);
lengthMSB = xbeeByte[1];
lengthLSB = xbeeByte[2];
for (int i = 3; i < lengthLSB + 4; i++) { // reset xbeeByte to 0 and = length to get checksum
delay(1);
frameType = xbeeByte[3];
frameID = xbeeByte[4];
checkSumCalc = 0;
if (frameType == 0x90 || frameType == 0x92) { //0x90 = 144
for (int i = 3; i < lengthLSB + 3; i++) {
checkSumCalc += xbeeByte[i];
delay(10);
byte checkSumByte = lengthLSB + 3;
byte checkSum = xbeeByte[checkSumByte]; // lengthLSB + 3
checkSumCalc &= 0xFF;
checkSumCalc = 0xFF - checkSumCalc;
if (checkSum == checkSumCalc && xbeeByte[lengthLSB + 2] == 69) {
for (int i = 0; i < lengthLSB + 4; i++) {
Serial.println("");
delay(1);
else if (checkSum == checkSumCalc && xbeeByte[2] == 18) {
Serial.println("");
delay(1);
Serial.flush();
void serialAvailable() {
addy5 = Serial.parseInt();
addy6 = Serial.parseInt();
addy7 = Serial.parseInt();
addy8 = Serial.parseInt();
save = Serial.parseInt(); // Write all data to xbee yet? 2 = yes, 0 = no
port = Serial.parseInt(); // Which digital pin to write to?
value = Serial.parseInt(); // Which value? 0/4 = low, 1/5 = high
if (save == 0) {
save = 0x0;
else if (save == 1) {
save = 0x2;
if (value == 0) {
value = 0x4;
else if (value == 1) { // 5 = high? But we want it low for now to make it move in that direction.
value = 0x5;
switch (port) {
case 0:
pin = '0';
case 1:
pin = '1';
case 2:
pin = '2';
case 3:
pin = '3';
case 4:
pin = '4';
case 5:
pin = '5';
case 6:
pin = '6';
command(save, pin, value);
void command(byte save, char pin, byte value ) {
xB.write((byte)0x7E);
xB.write((byte)0x0);
xB.write((byte)0x10);
xB.write((byte)0x17);
xB.write((byte)0x0); // Frame ID
xB.write((byte)0x00); // first byte
xB.write((byte)0x13); // 2
xB.write((byte)0xA2); // 3
xB.write((byte)0x00); // 4
xB.write(addy5); // 5
xB.write(addy6); // 6
xB.write(addy7); // 7
xB.write(addy8);// 8
xB.write((byte)0xFF); // "10"67
xB.write((byte)0xFE);// 10"66"
xB.write(save);
xB.write('D');
xB.write(pin);
xB.write(value);
long sum = 0x17 + 0x13 + 0xA2 + addy5 + addy6 + addy7 + addy8 + 0xFF + 0xFE + save + 'D' + pin + value;
xB.write((byte)0xFF - (sum & 0xFF));
delay(1);
A1_xbAvailable.ino (1.93 KB)
A2_serialAvailable.ino (1.69 KB)
arduino_forum_question.ino (2.48 KB)
