This is a question that came to mind when reading @PowerBroker's excellent Tutorial in the Introductory section. I don't want to derail the Tutorial
This is a quote from Reply #4 of the Tutorial
Consistent Overhead Byte Stuffing (or COBS) is a low-byte-overhead method of avoiding false start/end bytes within the packet payload. The main idea behind COBS is to add a field in the transmitted packet that contains a pointer. This pointer will point to the first occurrence of the value of the start/end byte in the original packet payload.
My own approach to sending data that may contain a value the same as a start- or end-marker has been to use a third marker byte. For example 254 might be the start marker and 255 might the end marker and 253 will be the "special character marker". When deciphering the incoming data if the system sees a 253 in the stream it will treat the following byte as a legitimate value rather than a marker. For example to include 254 in the stream one would send 253 254 and to include 253 in the stream one would send 253 253
My question is whether the COBS system is more efficient?
And, with a slightly different slant on the same problem (my preference being to send human readable characters) for some of my own projects I have developed a couple of small functions that will encode and decode a number into either 2 characters or 3 characters (depending on the size of the number) in the range (IIRC) ASCII 48 '0' to ASCII 111 'o'. This is a range of 64 characters. Two characters can store a value from 0 to 4160 and 3 characters can store up to 266,000. It allows for the data elements to be identified without needing separators (because the length is known in advance) and decoding is very much faster than the atoi() function.
...R
