Serial pin issue
I have a large network of Arduinos that communicate via serial. It came as a big surprise that if an Arduino is unpowered, the serial ports go to ground, dragging the whole network down. So if you've got a network and it suddenly goes stupid, see if you have an unpowered unit connected. I also see this failure if the voltage regulator on the Vin pin fails.
Sounds like you need to rethink your hardware design. Maybe you can get some improvement ideas from the forum when you share your schematics.
You have to use drivers (serial in this case) that go offline when the power fails. Another option would be to use a ?pole relay and connect via the NO contacts and power with the Arduino power source. Not the most elegant but maybe the easiest to retrofit.
Fortunately, all units are accessible and it's quick to find a failure. For some reason I thought a dead output would float, not short. I've only had one failure, and that was a regulator on a Nano. So the Nano programmed OK, but wouldn't work out in the world. Very hard to track down.
I do use hex 7400 line drivers, but when an input goes low, so does their output. All of the outputs get wire-AND together to feed all the inputs. It works pretty well. I suppose the serial combiner could be spiffed up with 2inputOR gates, and then use a Mega to do BIT and turn off any dead inputs, but I'm not liking the idea of a box to house the combiner that's as big as a twin bed. :grinning_face_with_smiling_eyes:
