Serial plotter doesn't show the graphe
hello guys, i have project consist of measure the heart rate with arduino uno and max30102 sensor but when i compile the code , it show's me the values of bpm in serial monitor but doesn't show me graph in serial plotter
here's the code
#include <Wire.h>
#include "MAX30105.h"
#include "heartRate.h"
MAX30105 particleSensor;
const byte RATE_SIZE = 4; //Increase this for more averaging. 4 is good.
byte rates[RATE_SIZE]; //Array of heart rates
byte rateSpot = 0;
long lastBeat = 0; //Time at which the last beat occurred
float beatsPerMinute;
int beatAvg;
  Serial.println("Initializing...");
  // Initialize sensor
  if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) {
    Serial.println("MAX30102 was not found. Please check wiring/power. ");
    while (1);
  Serial.println("Place your index finger on the sensor with steady pressure.");
  particleSensor.setup(); //Configure sensor with default settings
  particleSensor.setPulseAmplitudeRed(0x0A); //Turn Red LED to low to indicate sensor is running
  particleSensor.setPulseAmplitudeGreen(0); //Turn off Green LED
  long irValue = particleSensor.getIR();
  if (checkForBeat(irValue) == true) {
    //We sensed a beat!
    long delta = millis() - lastBeat;
    lastBeat = millis();
    beatsPerMinute = 60 / (delta / 1000.0);
    if (beatsPerMinute < 255 && beatsPerMinute > 20) {
      rates[rateSpot++] = (byte)beatsPerMinute; //Store this reading in the array
      rateSpot %= RATE_SIZE; //Wrap variable
      //Take average of readings
      beatAvg = 0;
      for (byte x = 0 ; x < RATE_SIZE ; x++)
        beatAvg += rates[x];
      beatAvg /= RATE_SIZE;
  Serial.print("IR=");
  Serial.print(irValue);
  Serial.print(", BPM=");
  Serial.print(beatsPerMinute);
  Serial.print(", Avg BPM=");
  Serial.print(beatAvg);
  if (irValue < 50000)
    Serial.print(" No finger?");
any solution please!
be careful how you output text with the numeric data
have a look at ide-v2-serial-plotter
yes thanks i tried to modify last section of the code in serial.print and it works as follows
 Serial.print("IR->");
  //Serial.print(",");
  Serial.print( irValue);
  Serial.print(",");
  Serial.print(" BPM->");
   Serial.print(",");
  Serial.print(",");
  Serial.print(" Avg_BPM->");
  Serial.print(",");
   Serial.print(",");
    Serial.print("No_Finger?");
and now it show's me the serial plotter graph thank you @horace
