Serial Plotter, need to control X Axis display
I have been able to generate an output on the IDE 2.0 Serial Plotter Tracking Temp, RH, CO2 it all works. However, the output is a sliding window containing only the most recent data points. Is there any way to capture more? (And/or to change the range to show more data points on the screen?) with only the last ~49 readings on the display, I can't get a sense of trending
Example plot
I am also suffering the same problem. The older versions did not behave this way. I can understand putting a limit on the graph history but some sort of x axis control would be helpful.
I submit this in order to keep the enquiry open for another 6 months!
IK
