I'm using python programming to boot the board and run some tests and post results into txt document. By using read() log repeats for each character, after using readline(), booting log is repeating for every new line it receives.
Any suggestion to handle the carriage return overcome the issue will be helpful.
#!/usr/bin/python3
import serial
import time
def enter_factory_mode(panel_type,panel_uart_com):
ser=serial.Serial(panel_uart_com,115200,timeout=0.5)
if(ser is None):
print("open serial failed")
return False
ser.write("\x03".encode())
print("%s do test" %panel_type)
set_mode_bit = False
response = ''
s_temp = ''
timeout = time.time()+120
while(True):
s_temp = ser.readline().decode("utf-8", "ignore")
response += s_temp
if timeout<time.time():
ser.close()
return False
if(set_test_mode_bit is False):
if(response.find("Reset cause: WDOG") != -1):
ser.write("\n".encode())
ser.write("setenv testmode 1\n".encode())
ser.write("boot\n".encode())
print("setenv factorymode 1")
print("boot")
set_test_mode_bit = True
response = ""
else:
print(response)
if(response.find(login_string) != -1):
ser.write("root\n".encode())
time.sleep(1)
print("user")
print("password")
time.sleep(1)
print("go to testmode successful")
set_testmode_bit = False
ser.close()
return True
print("enter testmode failed")
ser.close()
return False
def write_command(ser,command):
try:
ser.write(command.encode())
#time.sleep(1)
except:
print("error")
def get_result(ser,time_delay):
response = ''
s_temp = ''
time_delay_temp = int(time_delay)
if(time_delay_temp < 0.1):
print("please input the right time delay")
timeout = time.time()+time_delay_temp
while(True):
s_temp = ser.read().decode("utf-8", "ignore")
response += s_temp
break
return response
def main():
panel_type = ""
panel_uart_com = "/dev/ttyUSB0"
ret = enter_factory_mode(panel_type,panel_uart_com)
if(ret is False):
print('enter test mode failed')
return False
test(panel_type,panel_uart_com)
if __name__ == '__main__':
main()
image of output:
