Serial port control problem
i am doing some programming with my arduino to help me control a Microwave frequency converter i have built - i am trying to make a little control box that uses a Nano to drive 4 TTL control lines from different commands sent via the serial port to… pretty simple stuff…
each state is entered by typing 1/ or 2/… /6 this sets the four TTL lines to a cetain state.
I have 6 states i want the control lines to be in. The 6th state i want to have one of the lines turning on and off which i have sucessfully done.
What i can’t seem to do is once the code has entered the 6th state function i can’t write a new serial command and change the TTL lines back to one of the other 5 states
here is the code, the “if (digitalState == 6)…” is the function i am having trouble with with…
Thanks in advance to those who want to help out a Microwave engineer :wink:
Dan.
/*  4 Line LED drive via serila command
Type
1/  for 0101
2/  for 0110
3/  for 1000
4/  for 1001
5/  for 1010
6/  For what ever was programmed befor but with pin 4 blinking
unsigned long serialdata;
int inbyte;
int digitalState;
int pinNumber;
  getSerial();
                  digitalState = serialdata;
                  pinMode(2, OUTPUT); // sets pin to output
                  pinMode(3, OUTPUT); // sets pin to output
                  pinMode(4, OUTPUT); // sets pin to output
                  pinMode(5, OUTPUT); // sets pin to output
                  //Serial.println(serialdata);
                if (digitalState == 1)
                  Serial.print("18-23GHz Selected ");
                  digitalWrite(2, HIGH); // SW1_1
                  digitalWrite(3, LOW);  // SW1_1
                  digitalWrite(4, HIGH); // SW1_1
                  digitalWrite(5, LOW);  // SW1_1
                 if (digitalState == 2)
                  Serial.print("23-26.5GHz Selected ");
                  digitalWrite(2, LOW);
                  digitalWrite(3, HIGH);
                if (digitalState == 3)
                  Serial.print("26.5-33.599GHz Selected ");
                  digitalWrite(4, LOW);
                  digitalWrite(5, HIGH);
                if (digitalState == 4)
                  Serial.print("33.6-37.99GHz Selected ");
                  digitalWrite(46, LOW);
                if (digitalState == 5)
                  Serial.print("38-40GHz Selected ");
                if (digitalState == 6)  // makes pin 4 blink on and off - How do you allow this function to exit due to new serial command????
                  Serial.print("Pulse ");
                 while (digitalState == 6)
                //  cal();
                  delay(100);
                  delay(200);
                //  serialdata = Serial.read();
               // How do i make this loop exit when i type an other serial command   ????
long getSerial()    // Get serial data function
  serialdata = 0;
  while (inbyte != '/')
    inbyte = Serial.read();
    if (inbyte > 0 && inbyte != '/')
      serialdata = serialdata * 10 + inbyte - '0';
      Serial.print("   inbyte = ");
      Serial.println(inbyte);
  inbyte = 0;
   Serial.print("serial read function serialdata = ");
  return serialdata;
/[code]
[/code]
Hello,
Something like this?
Type
1  for 0101
2  for 0110
3  for 1000
4  for 1001
5  for 1010
6  For what ever was programmed befor but with pin 4 blinking
int inbyte;
int digitalState;
int pinNumber;
                  digitalState = Serial.read(); //implement the check for ascii digits on this.
                if (digitalState == '1')
                 if (digitalState == '2')
                if (digitalState == '3')
                if (digitalState == '4')
                if (digitalState == '5')
                if (digitalState == '6')  // makes pin 4 blink on and off - How do you allow this function to exit due to new serial command????
                 while (digitalState == '6')
                //  cal();
                  delay(100);
                  delay(200);
Not sure if you want to keep the LED blinking while receiving more ocmmands or if you want to blink only once.
If you want to turn on and off a blinking function, the easiest would be to integrate the blink without delay example here. :)
Thanks for your quick relpy.
i have tried this approach already and found that in your code, function 6 only runs once - the LED blinks once and then exits.
I would like the LED blink until i type in another command. Once my original code goes into the blink state code the ignores any new serial commands.
cheers
Dan
Danp: i have tried this approach already and found that in your code, function 6 only runs once - the LED blinks once and then exits.
Dan-
How about something like
  //  cal();
  delay(100);
  delay(200);
  if (Serial.available() > 0)
Hope this helps,
Brad KF7FER
EDIT: Perhaps maybe instead of the "digitalState = Serial.read();" line it might be better to do:
  getSerial();
But I suspect you get the idea.
