Serial Port Doesnt show up in the menu ( ide )
Hi All,
I am using the Arduino Uno ( with ATmega 328 ) . I have installed the gcc-arv and the other required libraries and headers. When i Connect the board and run dmesg it shows that it detected the device on ttyUSB0 [ 5593.075111] cfg80211: Found new beacon on frequency: 2472 MHz (Ch 13) on phy0 [ 6090.491867] usb 3-4: new full-speed USB device number 2 using xhci_hcd [ 6090.766376] usbcore: registered new interface driver usbserial [ 6090.766415] USB Serial support registered for generic [ 6090.766468] usbcore: registered new interface driver usbserial_generic [ 6090.766471] usbserial: USB Serial Driver core [ 6090.780854] USB Serial support registered for FTDI USB Serial Device [ 6090.780931] ftdi_sio 3-4:1.0: FTDI USB Serial Device converter detected [ 6090.780960] usb 3-4: Detected FT232RL [ 6090.780962] usb 3-4: Number of endpoints 2 [ 6090.780963] usb 3-4: Endpoint 1 MaxPacketSize 64 [ 6090.780965] usb 3-4: Endpoint 2 MaxPacketSize 64 [ 6090.780968] usb 3-4: Setting MaxPacketSize 64 [ 6090.781184] usb 3-4: FTDI USB Serial Device converter now attached to ttyUSB0 [ 6090.781205] usbcore: registered new interface driver ftdi_sio [ 6090.781207] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver [ 6134.677930] usb 3-4: USB disconnect, device number 2 [ 6134.678324] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0 [ 6134.678361] ftdi_sio 3-4:1.0: device disconnected [ 6251.731009] usb 3-4: new full-speed USB device number 3 using xhci_hcd [ 6251.756416] ftdi_sio 3-4:1.0: FTDI USB Serial Device converter detected [ 6251.756516] usb 3-4: Detected FT232RL [ 6251.756521] usb 3-4: Number of endpoints 2 [ 6251.756526] usb 3-4: Endpoint 1 MaxPacketSize 64 [ 6251.756531] usb 3-4: Endpoint 2 MaxPacketSize 64 [ 6251.756536] usb 3-4: Setting MaxPacketSize 64 [ 6251.756831] usb 3-4: FTDI USB Serial Device converter now attached to ttyUSB0 [ 6710.018992] usb 3-4: USB disconnect, device number 3 [ 6710.019385] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0 [ 6710.019421] ftdi_sio 3-4:1.0: device disconnected [ 7759.425171] usb 3-4: new full-speed USB device number 4 using xhci_hcd [ 7759.450444] ftdi_sio 3-4:1.0: FTDI USB Serial Device converter detected [ 7759.450540] usb 3-4: Detected FT232RL [ 7759.450546] usb 3-4: Number of endpoints 2 [ 7759.450551] usb 3-4: Endpoint 1 MaxPacketSize 64 [ 7759.450556] usb 3-4: Endpoint 2 MaxPacketSize 64 [ 7759.450560] usb 3-4: Setting MaxPacketSize 64 [ 7759.450844] usb 3-4: FTDI USB Serial Device converter now attached to ttyUSB0 [ 8192.081830] usb 3-4: USB disconnect, device number 4 [ 8192.082184] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0 [ 8192.082217] ftdi_sio 3-4:1.0: device disconnected [ 9243.097672] usb 3-4: new full-speed USB device number 5 using xhci_hcd [ 9243.122934] ftdi_sio 3-4:1.0: FTDI USB Serial Device converter detected [ 9243.123032] usb 3-4: Detected FT232RL [ 9243.123037] usb 3-4: Number of endpoints 2 [ 9243.123042] usb 3-4: Endpoint 1 MaxPacketSize 64 [ 9243.123047] usb 3-4: Endpoint 2 MaxPacketSize 64 [ 9243.123052] usb 3-4: Setting MaxPacketSize 64 [ 9243.123339] usb 3-4: FTDI USB Serial Device converter now attached to ttyUSB0 [ 9247.575615] usb 3-4: USB disconnect, device number 5 [ 9247.576009] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0 [ 9247.576046] ftdi_sio 3-4:1.0: device disconnected [ 9248.995188] usb 3-4: new full-speed USB device number 6 using xhci_hcd [ 9249.020261] ftdi_sio 3-4:1.0: FTDI USB Serial Device converter detected [ 9249.020357] usb 3-4: Detected FT232RL [ 9249.020362] usb 3-4: Number of endpoints 2 [ 9249.020367] usb 3-4: Endpoint 1 MaxPacketSize 64 [ 9249.020372] usb 3-4: Endpoint 2 MaxPacketSize 64 [ 9249.020377] usb 3-4: Setting MaxPacketSize 64 [ 9249.020747] usb 3-4: FTDI USB Serial Device converter now attached to ttyUSB0 [ 9364.611429] usb 3-4: USB disconnect, device number 6 [ 9364.611825] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0 [ 9364.611862] ftdi_sio 3-4:1.0: device disconnected [10097.672279] usb 3-4: new full-speed USB device number 7 using xhci_hcd [10097.697519] ftdi_sio 3-4:1.0: FTDI USB Serial Device converter detected [10097.697619] usb 3-4: Detected FT232RL [10097.697624] usb 3-4: Number of endpoints 2 [10097.697629] usb 3-4: Endpoint 1 MaxPacketSize 64 [10097.697634] usb 3-4: Endpoint 2 MaxPacketSize 64 [10097.697639] usb 3-4: Setting MaxPacketSize 64 [10097.697927] usb 3-4: FTDI USB Serial Device converter now attached to ttyUSB0 [10481.992780] usb 3-4: USB disconnect, device number 7 [10481.993089] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0 [10481.993116] ftdi_sio 3-4:1.0: device disconnected [10485.582661] usb 3-4: new full-speed USB device number 8 using xhci_hcd [10485.607859] ftdi_sio 3-4:1.0: FTDI USB Serial Device converter detected [10485.607912] usb 3-4: Detected FT232RL [10485.607915] usb 3-4: Number of endpoints 2 [10485.607918] usb 3-4: Endpoint 1 MaxPacketSize 64 [10485.607921] usb 3-4: Endpoint 2 MaxPacketSize 64 [10485.607923] usb 3-4: Setting MaxPacketSize 64 [10485.608266] usb 3-4: FTDI USB Serial Device converter now attached to ttyUSB0 [10539.786676] usb 3-4: USB disconnect, device number 8 [10539.786989] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0 [10539.787023] ftdi_sio 3-4:1.0: device disconnected [10633.596406] usb 3-4: new full-speed USB device number 9 using xhci_hcd [10633.621723] ftdi_sio 3-4:1.0: FTDI USB Serial Device converter detected [10633.621829] usb 3-4: Detected FT232RL [10633.621838] usb 3-4: Number of endpoints 2 [10633.621845] usb 3-4: Endpoint 1 MaxPacketSize 64 [10633.621853] usb 3-4: Endpoint 2 MaxPacketSize 64 [10633.621860] usb 3-4: Setting MaxPacketSize 64 [10633.622150] usb 3-4: FTDI USB Serial Device converter now attached to ttyUSB0
However , the tools menu doesnt show the serial port option ( disabled ) . Am using it on Ubuntu 12.04 LTS . Any Help is appreciated .
Thanks and Regards, Vijay
