Hi.
Please watch the video below.
So it's Leap Motion(hand position)-> Processing -> Arduino-> two servo motors(speed control).
Arduino Uno, Ada Fruit motor shield with 12V external power are used.
It works, but looks like Serial port fails after a minute (time varies) and arduino port disappears.
Works fine when relaunch processing script or USB cable replugged.
Is there a possibility that motors drain too much current from USB port despite the external power source and the computer shuts it down? It's Macbook Pro + OSX.
Thanks in advance.
processing code
import com.onformative.leap.;
import com.leapmotion.leap.;
import processing.serial.*;
PVector hand1_Pos = new PVector();
PVector hand2_Pos = new PVector();
ArrayList hands;
LeapMotionP5 leap;
int z[]=new int[2];
Serial port;
size(700, 700);
leap = new LeapMotionP5(this);
// set com port.
println("Available serial ports:");
println(Serial.list());
String portName = Serial.list()[2];
port = new Serial(this, portName , 57600);
void draw() {
hands = leap.getHandList();
background(0);
hand1_Pos = leap.getPosition(leap.getHand(0));
z[0]=(int)hand1_Pos.y;
fill(255,0,0); //Red
ellipse(hand1_Pos.x, hand1_Pos.y, 20, 20);
if(hands.size()>1){ // to prevent IndexOutOfBoundsException error
hand2_Pos = leap.getPosition(leap.getHand(1));
z[1]=(int)hand2_Pos.y;
fill(0,255,0); //Green
ellipse(hand2_Pos.x, hand2_Pos.y, 20, 20);
for (int i=0; i<z.length; i++){
port.write(z*);*
println(z[0]+" , "+z[1]);*
arduino code
#include <Servo.h>
Servo myServoL;
Servo myServoR;
int angleL, angleR ;
int valR, valL;
Serial.begin(57600);*
myServoL.attach(9);*
myServoR.attach(10);*
myServoL.write(0);*
myServoR.write(0);*
void loop() { -
byte z1=0;*
byte z2=0;*
if (Serial.available()) {*
// Read values from Processing*
z1 = Serial.read();*
if(Serial.available()>2){*
z2 = Serial.read();*
// servo*
valL = (int)map(z1,0,700, 1, 10); // lower pitch string*
valR = (int)map(z2,0,700, 1,10);*
for(angleL=70; angleL<100; angleL+=valL){*
myServoL.write(angleL);*
delay(10);*
for(angleR=70; angleR<100; angleR+=valR){*
myServoR.write(angleR);*
delay(10);*
for(angleL=100; angleL>=70; angleL=-valL){*
for(angleR=100; angleR>=70; angleR=-valR){*
