I've been googling this question and trying things for several days with no luck.
Basically I'm not able to upload any code to my Arduino (I use an Uno and a Mega) because the Port is greyed out. I'm using a Lenovo yoga 900 and am running fedora 23. I think an issue is that I don't have serial ports "ttyACM0", mine are called "tty##" and "ttyS##".
Basically, nothing I've found anywhere has helped me (my baud rate is correct, running as sudo doesn't help, etc) so I'm just looking for new insight.
thank you!
also, when i type ls /dev/ttyUSB* /dev/ttyACM* to the command line, it returns "No such file or directory" for both. is this part of the problem and if so what's the solution?
When I execute lsusb in a Terminal window, I see an entry for the Arduino SA Uno R3
ieee488:
I get the same -- "Bus 001 Device 005: ID 2341:0043 Arduino SA Uno R3 (CDC ACM)"
I am using IDE 1.6.7 in Linux Mint 17.3
No problems.
ieee488:
No problems.
I'm using 1.6.4, Fedora 23. If that helps..
