this is my program, can you look what debug should i use so it will not freeze
Imports System
Imports System.IO.Ports
Imports System.Threading
Imports System.ComponentModel
Public Class Form1
Dim comPORT As String
Dim receivedData As String = “”
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
'TODO: This line of code loads data into the ‘Cashsectiondb_01DataSet1.studinfo’ table. You can move, or remove it, as needed.
Me.StudinfoTableAdapter.Fill(Me.Cashsectiondb_01DataSet1.studinfo)
Timer1.Enabled = False
comPORT = “”
For Each sp As String In My.Computer.Ports.SerialPortNames
comPort_ComboBox.Items.Add(sp)
Next
End Sub
Private Sub comPort_ComboBox_SelectedIndexChanged(sender As Object, e As EventArgs) Handles comPort_ComboBox.SelectedIndexChanged
If (comPort_ComboBox.SelectedItem <> “”) Then
comPORT = comPort_ComboBox.SelectedItem
End If
End Sub
Private Sub connect_BTN_Click(sender As Object, e As EventArgs) Handles connect_BTN.Click
If (connect_BTN.Text = “Connect”) Then
If (comPORT <> “”) Then
SerialPort1.Close()
SerialPort1.PortName = comPORT
SerialPort1.BaudRate = 9600
SerialPort1.DataBits = 8
SerialPort1.Parity = Parity.None
SerialPort1.StopBits = StopBits.One
SerialPort1.Handshake = Handshake.None
SerialPort1.Encoding = System.Text.Encoding.Default
SerialPort1.ReadTimeout = 10000
SerialPort1.Open()
connect_BTN.Text = “Dis-connect”
Timer1.Enabled = True
Timer_LBL.Text = “Timer: ON”
Else
MsgBox(“Select a COM port first”)
End If
Else
SerialPort1.Close()
Timer_LBL.Text = “Timer: OFF”
End If
End Sub
Private Sub Timer1_Tick(sender As Object, e As EventArgs) Handles Timer1.Tick
receivedData = ReceiveSerialData()
RichTextBox1.Text &= receivedData
Try
If RichTextBox1.Text = “” Then
SerialPort1.ReadLine()
Me.StudinfoBindingSource.MoveNext()
End If
Catch ex As Exception
End Try
End Sub
Function ReceiveSerialData() As String
Dim Incoming As String
Try
Incoming = SerialPort1.ReadExisting()
If Incoming Is Nothing Then
Return “nothing” & vbCrLf
Else
Return Incoming
End If
Catch ex As TimeoutException
Return “Error: Serial Port read timed out.”
End Try
End Function
Private Sub clear_BTN_Click(sender As Object, e As EventArgs) Handles clear_BTN.Click
End Sub
Private Sub StudinfoBindingNavigatorSaveItem_Click(sender As Object, e As EventArgs) Handles StudinfoBindingNavigatorSaveItem.Click
Me.Validate()
Me.StudinfoBindingSource.EndEdit()
Me.TableAdapterManager.UpdateAll(Me.Cashsectiondb_01DataSet1)
End Sub
End Class
