Serial Port in Midi Library 3.1
Hi all
I am using Mega2560 and I would like to use Midi Library for PC to Arduino communication.
I would like to use the Serial1 (Pin 18,19) for doing it. but I can't find and reference or simple for change the Serial port in function.
from playground
http://www.arduino.cc/playground/Main/MIDILibrary
Compatible with all Arduino boards. Possibility to choose which serial port to use if more than one available.
Class function reference
http://arduinomidilib.sourceforge.net/a00001.html#ac34d163205bb01ac5e03df7e64facebe
I have been searching in forum but only find v2.5 is no support...
Thank you :slight_smile:
Apparently you are supposed to change this line in MIDI.h:
#define USE_SERIAL_PORT Serial
You also need to use the #20 version of the Arduino IDE. Above versions do not compile well the Midi library. Otherwise you'll get errors like this one when compiling.
ERROR : 'Serial' was not declared in this scope
Also, you may want to update the code and replace the call for
Midi midi(Serial);
by
Midi midi(Serial[color=red]x[/color]);
where x stands for either 1 or 2, considering the Mega UARTS.
