Serial Port In Use in OSX 10.5.6
I get the following error when I go to upload:
Couldn’t determine program size: text data bss dec hex filename
processing.app.SerialException: Serial port ‘/dev/cu.SGH-A737-SerialServer-1’ already in use. Try quiting any programs that may be using it.
at processing.app.Serial.(Serial.java:140)
at processing.app.Serial.(Serial.java:72)
at processing.app.Uploader.flushSerialBuffer(Uploader.java:66)
at processing.app.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:73)
at processing.app.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:48)
at processing.app.Sketch.upload(Sketch.java:1632)
at processing.app.Sketch.exportApplet(Sketch.java:1701)
at processing.app.Editor$41.run(Editor.java:2004)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
I have tried the
"3) Delete /System/Library/Extensions/FTDIUSBSerialDriver.kext
  1. Delete /System/Library/Extensions.kextcache
  2. Delete /System/Library/Caches/com.apple.kernelcaches/*
  3. Delete /Library/Receipts/FTDIUSBSerialDriver.pkg
  4. Delete /Library/Receipts/FTDIUSBSerialDriver.kext"
and I’ve reinstalled 2.2.10 of FTDI but I still get the error. Is there some way to determine what is holding up the serial port? I’ve also tried chmod 777 in a lock directory.
That is almost certainly not the right serial port. That looks like a Samsung mobile modem connection or something.
It should be something like /dev/tty.usbserial-XXXXXXXX
I'd recommend against using the "cu" device anyway.
and you are most certainly right. I was having this problem with a diecimila and the proper serial port wasn't showing. I switched to a '09, the right port came up, plugged the diecimila back in and the port appeared again. Oh well the 2 hour struggle was a good lesson in terminal.
Now back to programming the line following robot...
