Serial port interfere with an e-paper panel
Hi, I'm new to the forum and this is the first thread I've opened, so I apologize in advance in case I'm breaking any community guidelines.
I'm fairly new to using arduino.
I pose the problem that has presented itself to me.
I'm using with arduino UNO an e-paper screen, to be precise one of WaveShare, 2.9 inch V2, black and white.
I have already implemented several functions that for now I'm not going to specify not to prolong, if necessary I am willing to explain.
The point is that right now I'm trying to interface arduino with a web page and consequently I need to open the serial port to pass data to the server. However, only by inserting Serial.begin() in the script the screen basically stops working, which seems strange to me, because in the example screen script the serial port is opened and it works. So I am asking if someone more experienced or who has already faced a similar problem could help me.
I hope I have explained myself, I am available for any clarifications on the project you need.
Thanks a lot.
#include <SPI.h>
#include "epd2in9_V2.h"
#include "epdpaint.h"
#include "imagedata.h"
#define COLORED     0
#define UNCOLORED   1
#define HALL_PIN 6
#define GREEN_PIN 5
#define RED_PIN 4
#define BLUE_PIN 3
#define PWBUTTON_PIN 2
#define MBUTTON_PIN 1
byte lastPWButtonState = LOW;
byte lastMButtonState = LOW;
byte GledState = LOW;
byte RledState = LOW;
byte BledState = LOW;
unsigned long debounceDuration = 50; // millis
unsigned long lastTimeButtonStateChanged = 0;
unsigned long CurrentTime = 0;
unsigned long RegisterTime = 3000;
    Due to RAM not enough in Arduino UNO, a frame buffer is not allowed.
    In this case, a smaller image buffer is allocated and you have to
    update a partial display several times.
    1 byte = 8 pixels, therefore you have to set 8*N pixels at a time.
unsigned char image[1024];
Paint paint(image, 0, 0);    // width should be the multiple of 8
Epd epd;
//unsigned long time_start_ms;
//unsigned long time_now_s;
char ContaGiri1[] = {'M', 'a', 'i', 'l', ':', '0', '0', '0', '\0'};
char ContaGiri2[] = {'m', 'i', 'n', '/', 'V', 'i', 'd', 'e', 'o', ':', '0', '0', '0', '\0'};
char ContaGiri3[] = {'m', 'i', 'n', '/', 'W', 'e', 'b', ':', '0', '0', '0', '\0'};
int Status = 0;
int giri = 0;
int RPM = 0;
float energia = 0;
float connection_time = 0;
bool print_count = false;
bool connection_ended = false;
int gmail = 0;
int gmailold = 0;
int gvid = 0;
int gvidold = 0;
int gweb = 0;
int gwebold = 0;
int connection = 0;
int oldconnection = 0;
  pinMode(HALL_PIN, INPUT);
  pinMode(GREEN_PIN, OUTPUT);
  pinMode(RED_PIN, OUTPUT);
  pinMode(BLUE_PIN, OUTPUT);
  pinMode(PWBUTTON_PIN, INPUT);
  pinMode(MBUTTON_PIN, INPUT);
  if (epd.Init() != 0) {
    Serial.print("e-Paper init failed");
    return;
  epd.ClearFrameMemory(0xFF);   // bit set = white, bit reset = black
  epd.DisplayFrame();
  //if (epd.Init() != 0) {
  //Serial.print("e-Paper init failed ");
  //return;
  CurrentTime = millis();
  connection_time = millis();
  int Digital;
  int refresh = 0;
  Digital = digitalRead (HALL_PIN);
  if (millis() - lastTimeButtonStateChanged > debounceDuration) {
    byte PWbuttonState = digitalRead(PWBUTTON_PIN);
    if (PWbuttonState != lastPWButtonState) {
      lastTimeButtonStateChanged = millis();
      lastPWButtonState = PWbuttonState;
      if (PWbuttonState == LOW) {
        if (GledState == HIGH) {
          GledState = LOW;
          epd.Init();
          epd.SetFrameMemory_Base(IMAGE_DATA3);
          epd.DisplayFrame();
          connection = 0;
          GledState = HIGH;
        digitalWrite(GREEN_PIN, GledState);
    byte MbuttonState = digitalRead(MBUTTON_PIN);
      if (MbuttonState != lastMButtonState) {
        lastMButtonState = MbuttonState;
        if (MbuttonState == LOW) {
          if (RledState == HIGH) {
            RledState = LOW;
            BledState = HIGH;
            digitalWrite(RED_PIN, RledState);
            digitalWrite(BLUE_PIN, BledState);
            energia = energia * 1000;
            if (millis() - connection_time > energia) {
              epd.Init();
              epd.SetFrameMemory_Base(IMAGE_DATA5);
              epd.DisplayFrame();
              connection = 0;
              epd.Init();
              epd.SetFrameMemory_Base(IMAGE_DATA4);
              epd.DisplayFrame();
              connection = 1;
          else {
            RledState = HIGH;
            BledState = LOW;
            epd.Init();
            epd.SetFrameMemory_Base(IMAGE_DATA2);
            epd.DisplayFrame();
            energia = energia - (millis() - connection_time);
            energia = energia / 1000;
            connection = 0;
      RledState = LOW;
      BledState = LOW;
      connection = 0;
    if (connection_ended == true) {
      ContaGiri1[5] = '0';
      ContaGiri1[6] = '0';
      ContaGiri1[7] = '0';
      ContaGiri2[10] = '0';
      ContaGiri2[11] = '0';
      ContaGiri2[12] = '0';
      ContaGiri3[8] = '0';
      ContaGiri3[9] = '0';
      ContaGiri3[10] = '0';
    if (Digital == 0 && Status == 1) {
      refresh = 1;
      giri++;
      gmail = giri / 8;
      gvid = giri / 15;
      gweb = giri / 5;
      if (ContaGiri1[7] < '9' && gmail != gmailold ) {
        ContaGiri1[7] = ContaGiri1[7] + 1;
        gmailold = gmail;
      } else if (gmail != gmailold) {
        if (ContaGiri1[6] < '9' && gmail != gmailold) {
          ContaGiri1[6] = ContaGiri1[6] + 1;
          gmailold = gmail;
          ContaGiri1[5] = ContaGiri1[5] + 1;
          gmailold = gmail;
      if (ContaGiri2[12] < '9' && gvid != gvidold ) {
        ContaGiri2[12] = ContaGiri2[12] + 1;
        gvidold = gvid;
      } else if (gvid != gvidold) {
        if (ContaGiri2[11] < '9' && gvid != gvidold) {
          ContaGiri2[11] = ContaGiri2[11] + 1;
          gvidold = gvid;
          ContaGiri2[10] = ContaGiri2[10] + 1;
          gvidold = gvid;
      if (ContaGiri3[10] < '9' && gweb != gwebold ) {
        ContaGiri3[10] = ContaGiri3[10] + 1;
        gwebold = gweb;
      } else if (gweb != gwebold) {
        if (ContaGiri3[9] < '9' && gweb != gwebold) {
          ContaGiri3[9] = ContaGiri3[9] + 1;
          gwebold = gweb;
          ContaGiri3[8] = ContaGiri3[8] + 1;
          gwebold = gweb;
      Status = 0;
    else if (Digital == 1) {
      Status = 1;
      refresh = 0;
    if (millis() - CurrentTime > RegisterTime) {
      RPM = giri * 8;
      paint.SetRotate(ROTATE_0);
      paint.SetWidth(90);
      paint.SetHeight(12);
      paint.Clear(UNCOLORED);
      paint.DrawStringAt(0, 0, ContaGiri1, &Font12, COLORED);
      epd.SetFrameMemory_Partial(paint.GetImage(), 0, 80, paint.GetWidth(), paint.GetHeight());
      paint.DrawStringAt(0, 0, ContaGiri2, &Font12, COLORED);
      epd.SetFrameMemory_Partial(paint.GetImage(), 0, 90, paint.GetWidth(), paint.GetHeight());
      paint.DrawStringAt(0, 0, ContaGiri3, &Font12, COLORED);
      epd.SetFrameMemory_Partial(paint.GetImage(), 0, 100, paint.GetWidth(), paint.GetHeight());
      paint.SetRotate(ROTATE_180);
      paint.SetWidth(60);
      paint.SetHeight(125);
      paint.DrawFilledRectangle(0, 0, 60, RPM , COLORED);
      epd.SetFrameMemory_Partial(paint.GetImage(), 0, 172, paint.GetWidth(), paint.GetHeight());
      epd.DisplayFrame_Partial();
      RPM = 0;
      energia = energia + giri;
      giri = 0;
  } else if (BledState == HIGH) {
    // traduzione giri in tempo
    if (print_count == false) {
        epd.Init();
        epd.DisplayFrame();
        print_count = true;
        energia = 0;
        connection_ended = true;
I don't have a schematic of the wiring (in programs like thinkercad i cannot find my hall sensor or my screen) but I have all the photos needed (i hope) to understand how it is done. The forum doesn't allow to new members to post multiple media, so I'm gonna upload my wiring on github.
That's the GitHub link to see the two different scripts and the wiring.
We need to see your wiring. Post a schematic showing how the wiring should be. Post photos showing how the wiring is.
Post the code that you uploaded to the Uno. Read the forum guidelines to see how to properly post code and some information on how to get the most from this forum.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
May be related to this post. But you did not report processor used nor board selected to compile for.
Ok, sorry, I did not read precisely enough. You use an Arduino UNO, so it is not related to this issue.
Think now is all good, except for the schematic. Thank u
Pin number 1 is Serial TX on UNO.
I hope this answer helps.
I'm sorry, but I don't understand what I should do, that's my first Arduino project. Should I leave pin 1 free or do something else in the code?
Yes, try to use a different pin for MBUTTON_PIN.
Ok it worked, thanks a lot!!
