Serial Port List
Hi
I,m new to Arduino, and my problem is that the list for Serial Ports only shows;
/dev/tty.Bluetooth-Modem
/dev/cu.Bluetooth-Modem
/dev/tty.Bluetooth-PDA-Sync
/dev/cu.Bluetooth-PDA-Sync
and I want to connect to the USB port
I'm running a MacBook Pro with OS 10.5.4
Thanks
ktaylor01
Sounds like you haven't loaded the FTDI drivers yet?
-j
I’ve run the FTDIUSBSerialDriver_v2_2_9Intel.dmg which advises me it’s been install successfully.
And I’ve restarted as instructed.
Where should these files go? I could see if they are in the right place.
ktaylor01
Have you plugged in the Arduino before asking for the list? It will only appear on the list once the drivers are installed and it is plugged in. Try quiting and then re running the Arduino environment after it has been plugged in.
That's it
Thank You
ktaylor01
