Hi guys,
Was working on my sketch and allovasudden for no apparent reason I couldn’t communicate with my board and upon further inspection I noticed that I can’t even select the serial port as it’s greyed out. I uninstalled and reinstalled my IDE to no avail. Here’s the error code I’m getting:
Binary sketch size: 5,062 bytes (of a 30,720 byte maximum)
processing.app.SerialNotFoundException: Serial port '/dev/ttyUSB0' not found. Did you select the right one from the Tools > Serial Port menu?
at processing.app.Serial.<init>(Serial.java:191)
at processing.app.Serial.<init>(Serial.java:77)
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:77)
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:175)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
at processing.app.Sketch.upload(Sketch.java:1671)
at processing.app.Sketch.exportApplet(Sketch.java:1627)
at processing.app.Sketch.exportApplet(Sketch.java:1599)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2380)
at java.lang.Thread.run(Thread.java:745)
Any idea what may be causing this?
