An additional thing from the thread I referenced. Here's the copy/paste from running the app. I also followed the steps for running the serial discovery tool, but it only found the bluetooth stuff, not anything related to the arduino board.
(base) MBP-GDAC-6:Applications greg$ /Applications/"Arduino IDE.app"/Contents/MacOS/"Arduino IDE"
Arduino IDE 2.3.4
Checking for frontend application configuration customizations. Module path: /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/electron-main.js, destination 'package.json': /Applications/Arduino IDE.app/Contents/Resources/app/package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.4" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.1.1" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-12-03T10:01:12.470Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.4","cliVersion":"1.1.1","buildDate":"2024-12-03T10:01:12.470Z"}
Starting backend process. PID: 22453
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///Users/greg/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-01-20T15:00:59.593Z root INFO Backend Object.initialize: 6.3 ms [Finished 0.645 s after backend start]
2025-01-20T15:00:59.599Z root INFO Backend Object.configure: 5.6 ms [Finished 0.645 s after backend start]
2025-01-20T15:00:59.599Z root INFO Backend s.onStart: 1.9 ms [Finished 0.645 s after backend start]
2025-01-20T15:00:59.599Z root INFO Backend s.configure: 0.4 ms [Finished 0.670 s after backend start]
2025-01-20T15:00:59.600Z root INFO Backend d.onStart: 0.4 ms [Finished 0.670 s after backend start]
2025-01-20T15:00:59.601Z root INFO Backend d.configure: 0.1 ms [Finished 0.670 s after backend start]
2025-01-20T15:00:59.602Z root INFO Backend d.initialize: 25.7 ms [Finished 0.671 s after backend start]
2025-01-20T15:00:59.602Z root INFO Backend c.onStart: 0.4 ms [Finished 0.671 s after backend start]
2025-01-20T15:00:59.602Z root INFO Backend a.configure: 6.5 ms [Finished 0.677 s after backend start]
2025-01-20T15:00:59.604Z config INFO >>> Initializing CLI configuration...
2025-01-20T15:00:59.604Z root INFO Backend c.initialize: 0.7 ms [Finished 0.678 s after backend start]
2025-01-20T15:00:59.604Z root INFO Backend x.onStart: 0.9 ms [Finished 0.678 s after backend start]
2025-01-20T15:00:59.605Z config INFO Loading CLI configuration from /Users/greg/.arduinoIDE/arduino-cli.yaml...
2025-01-20T15:00:59.605Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2025-01-20T15:00:59.605Z root INFO Backend a.initialize: 0.5 ms [Finished 0.679 s after backend start]
2025-01-20T15:00:59.606Z root INFO Backend w.onStart: 1.3 ms [Finished 0.680 s after backend start]
2025-01-20T15:00:59.606Z root INFO Backend r.configure: 1.9 ms [Finished 0.680 s after backend start]
2025-01-20T15:00:59.606Z discovery-log INFO start
2025-01-20T15:00:59.606Z discovery-log INFO start new deferred
2025-01-20T15:00:59.606Z root INFO Backend d.initialize: 0.4 ms [Finished 0.681 s after backend start]
2025-01-20T15:00:59.606Z root INFO Backend y.onStart: 1.9 ms [Finished 0.682 s after backend start]
2025-01-20T15:00:59.606Z root INFO Backend r.configure: 1.6 ms [Finished 0.682 s after backend start]
2025-01-20T15:00:59.606Z root INFO Backend a.onStart: 0.7 ms [Finished 0.684 s after backend start]
2025-01-20T15:00:59.606Z root INFO Backend h.configure: 0.5 ms [Finished 0.684 s after backend start]
2025-01-20T15:00:59.606Z root INFO Backend s.configure: 0.1 ms [Finished 0.684 s after backend start]
2025-01-20T15:00:59.606Z root INFO Backend l.configure: 0.1 ms [Finished 0.684 s after backend start]
2025-01-20T15:00:59.608Z root INFO Theia app listening on http://127.0.0.1:53388.
2025-01-20T15:00:59.608Z root INFO Finished starting backend application: 2.7 ms [Finished 0.686 s after backend start]
2025-01-20T15:00:59.609Z root WARN The local plugin referenced by local-dir:/Users/greg/.arduinoIDE/extensions does not exist.
2025-01-20T15:00:59.610Z root WARN The local plugin referenced by local-dir:/Users/greg/.arduinoIDE/plugins does not exist.
2025-01-20T15:00:59.639Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]}}
2025-01-20T15:00:59.639Z config INFO Loading fallback CLI configuration to get 'directories.data' and 'directories.user'
2025-01-20T15:00:59.657Z root INFO Resolve plugins list: 52.9 ms [Finished 0.735 s after backend start]
2025-01-20T15:01:00.154Z daemon INFO time="2025-01-20T07:01:00-08:00" level=info msg="arduino-cli version 1.1.1"
time="2025-01-20T07:01:00-08:00" level=info msg="Using config file: /Users/greg/.arduinoIDE/arduino-cli.yaml"
time="2025-01-20T07:01:00-08:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:53389
{"IP":"127.0.0.1","Port":"53389"}
2025-01-20T15:01:00.154Z daemon INFO Daemon is running.
2025-01-20T15:01:00.155Z config INFO Loaded fallback CLI configuration: {"directories":{"user":"/Users/greg/Documents/Arduino","data":"/Users/greg/Library/Arduino15"}}
2025-01-20T15:01:00.155Z config INFO Merged CLI configuration with the fallback: {"directories":{"user":"/Users/greg/Documents/Arduino","data":"/Users/greg/Library/Arduino15"},"board_manager":{"additional_urls":[]}}
2025-01-20T15:01:00.155Z config INFO Loaded the CLI configuration.
2025-01-20T15:01:00.163Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///Users/greg/Library/Arduino15","sketchDirUri":"file:///Users/greg/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2025-01-20T15:01:00.163Z config INFO Validating the CLI configuration...
2025-01-20T15:01:00.232Z config INFO The CLI config is valid.
2025-01-20T15:01:00.232Z config INFO <<< Initialized the CLI configuration.
2025-01-20T15:01:00.287Z daemon INFO time="2025-01-20T07:01:00-08:00" level=info msg="Checking signature" index=/Users/greg/Library/Arduino15/package_index.json signatureFile=/Users/greg/Library/Arduino15/package_index.json.sig trusted=true
time="2025-01-20T07:01:00-08:00" level=info msg="Loading hardware from: /Users/greg/Library/Arduino15/packages"
time="2025-01-20T07:01:00-08:00" level=info msg="Loading package arduino from: /Users/greg/Library/Arduino15/packages/arduino/hardware"
time="2025-01-20T07:01:00-08:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-01-20T07:01:00-08:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2025-01-20T07:01:00-08:00" level=info msg="Checking existence of 'tools' path: /Users/greg/Library/Arduino15/packages/arduino/tools"
time="2025-01-20T07:01:00-08:00" level=info msg="Loading tools from dir: /Users/greg/Library/Arduino15/packages/arduino/tools"
time="2025-01-20T07:01:00-08:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2025-01-20T07:01:00-08:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2025-01-20T07:01:00-08:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2025-01-20T07:01:00-08:00" level=info msg="Loading package builtin from: /Users/greg/Library/Arduino15/packages/builtin"
time="2025-01-20T07:01:00-08:00" level=info msg="Checking existence of 'tools' path: /Users/greg/Library/Arduino15/packages/builtin/tools"
time="2025-01-20T07:01:00-08:00" level=info msg="Loading tools from dir: /Users/greg/Library/Arduino15/packages/builtin/tools"
time="2025-01-20T07:01:00-08:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2025-01-20T07:01:00-08:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2025-01-20T07:01:00-08:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2025-01-20T07:01:00-08:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2025-01-20T07:01:00-08:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2025-01-20T07:01:00-08:00" level=info msg="Adding libraries dir" dir=/Users/greg/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries isSingleLibrary=false location=platform
time="2025-01-20T07:01:00-08:00" level=info msg="Loading libraries index file" index=/Users/greg/Library/Arduino15/library_index.json
2025-01-20T15:01:00.636Z daemon INFO time="2025-01-20T07:01:00-08:00" level=info msg="Adding libraries dir" dir=/Users/greg/Library/Arduino15/libraries isSingleLibrary=false location=ide
time="2025-01-20T07:01:00-08:00" level=info msg="Adding libraries dir" dir=/Users/greg/Documents/Arduino/libraries isSingleLibrary=false location=user
2025-01-20T15:01:00.659Z discovery-log INFO start resolved watching
2025-01-20T15:01:00.775Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.BLTH","label":"/dev/cu.BLTH","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-01-20T15:01:00.777Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.Bluetooth-Incoming-Port","label":"/dev/cu.Bluetooth-Incoming-Port","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-01-20T15:01:01.091Z root INFO Deploy plugins list: 52.9 ms [Finished 2.170 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2025-01-20T15:01:02.461Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 260.4 ms [Finished 2.491 s after frontend start]
2025-01-20T15:01:02.464Z root WARN A command editor.action.toggleStickyScroll is already registered.
2025-01-20T15:01:02.529Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 101.0 ms [Finished 2.624 s after frontend start]
2025-01-20T15:01:02.801Z root INFO Start frontend contributions: 686.4 ms [Finished 2.818 s after frontend start]
2025-01-20T15:01:02.802Z root INFO Changed application state from 'init' to 'started_contributions'.
2025-01-20T15:01:02.814Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2025-01-20T15:01:02.815Z root INFO >>> Restoring the layout state...
2025-01-20T15:01:02.815Z root INFO <<< Nothing to restore.
2025-01-20T15:01:02.863Z root INFO Initialize the workbench layout: 28.1 ms [Finished 2.963 s after frontend start]
2025-01-20T15:01:02.884Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2025-01-20T15:01:03.088Z root INFO [d19f083e-3b94-47a8-8d14-a2fd4bcc60f4] Waiting for backend deployment: 407.1 ms [Finished 3.204 s after frontend start]
Checking for update
2025-01-20T15:01:04.526Z root INFO Replace loading indicator with ready workbench UI (animation): 933.5 ms [Finished 3.938 s after frontend start]
2025-01-20T15:01:04.526Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2025-01-20T15:01:04.526Z root WARN Linked preference "workbench.colorCustomizations" not found.
2025-01-20T15:01:04.529Z root INFO Frontend application start: 2105.4 ms [Finished 5.547 s after backend start]
2025-01-20T15:01:04.540Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464) starting instance
Update for version 2.3.4 is not available (latest version: 2.3.4, downgrade is allowed).
2025-01-20T15:01:05.570Z root ERROR ---- !!!SLOW!!! DURATION: search took 1045.033 ms. Args: [{"type":"Updatable"}] ----
2025-01-20T15:01:06.312Z root INFO [d19f083e-3b94-47a8-8d14-a2fd4bcc60f4] Sync of 23 plugins: 3202.8 ms [Finished 6.407 s after frontend start]
2025-01-20T15:01:06.314Z root INFO [d19f083e-3b94-47a8-8d14-a2fd4bcc60f4] Loading plugin contributions
2025-01-20T15:01:06.314Z root INFO [d19f083e-3b94-47a8-8d14-a2fd4bcc60f4] Load contributions of 23 plugins: 23.6 ms [Finished 6.431 s after frontend start]
2025-01-20T15:01:06.394Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2025-01-20T15:01:06.395Z root WARN a registered grammar configuration for 'cpp' language is overridden
2025-01-20T15:01:06.509Z daemon INFO time="2025-01-20T07:01:06-08:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
time="2025-01-20T07:01:06-08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
time="2025-01-20T07:01:06-08:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2025-01-20T15:01:06.512Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2025-01-20T15:01:06.514Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2025-01-20 07:01:06.814 Arduino IDE Helper (Renderer)[22457:815758] CoreText note: Client requested name ".NewYork-Regular", it will get TimesNewRomanPSMT rather than the intended font. All system UI font access should be through proper APIs such as CTFontCreateUIFontForLanguage() or +[NSFont systemFontOfSize:].
2025-01-20 07:01:06.814 Arduino IDE Helper (Renderer)[22457:815758] CoreText note: Set a breakpoint on CTFontLogSystemFontNameRequest to debug.
2025-01-20T15:01:07.092Z root ERROR [hosted-plugin: 22464] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2025-01-20T15:01:07.093Z root ERROR [hosted-plugin: 22464] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2025-01-20T15:01:07.134Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): PluginManagerExtImpl/init()
2025-01-20T15:01:07.136Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-arduino-api@0.1.2 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.238Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(cortex-debug@1.5.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.240Z root INFO [hosted-plugin: 22464] Debugger contribution has been registered: cortex-debug
2025-01-20T15:01:07.249Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-arduino-tools@0.1.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.257Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(cpp@1.52.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.258Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(json@1.46.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.260Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(json-language-features@1.46.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.266Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-language-pack-bg@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.268Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-language-pack-cs@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.269Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-language-pack-de@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.271Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-language-pack-es@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.277Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-language-pack-fr@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.282Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-language-pack-hu@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.285Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-language-pack-it@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.288Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-language-pack-ja@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.420Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-language-pack-ko@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.435Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-language-pack-nl@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.436Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-language-pack-pl@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.436Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-language-pack-pt-BR@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.437Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-language-pack-ru@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.438Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-language-pack-tr@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.438Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-language-pack-uk@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.439Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-language-pack-zh-hans@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.441Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): initializing(vscode-language-pack-zh-hant@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2025-01-20T15:01:07.509Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-api/extension/dist/extension.js)
2025-01-20T15:01:07.518Z root INFO [hosted-plugin: 22464] calling activation function on Arduino IDE API for VS Code extensions
2025-01-20T15:01:08.320Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-json-language-features/extension/client/dist/jsonMain)
2025-01-20T15:01:08.367Z root INFO [hosted-plugin: 22464] calling activation function on JSON Language Features (built-in)
2025-01-20T15:01:08.419Z root INFO [d19f083e-3b94-47a8-8d14-a2fd4bcc60f4] Starting plugins.
2025-01-20T15:01:08.516Z root INFO [hosted-plugin: 22464] PLUGIN_HOST(22464): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/cortex-debug/extension/dist/extension.js)
2025-01-20T15:01:08.586Z root INFO [hosted-plugin: 22464] Debug configuration provider has been registered: cortex-debug, trigger: 1
calling activation function on Cortex-Debug
2025-01-20T15:01:08.619Z root INFO [hosted-plugin: 22464] GDB server console created
2025-01-20T15:01:08.733Z root INFO [d19f083e-3b94-47a8-8d14-a2fd4bcc60f4] Start of 23 plugins: 2399.0 ms [Finished 8.847 s after frontend start]
2025-01-20T15:01:08.773Z root WARN Timeout after 5000 millis. The editor has not shown up in time. URI: file:///private/var/folders/hz/g9wxnq8147jd4khm6tqpqy3r3xx7lp/T/.arduinoIDE-unsaved2025020-22453-z9x9nb.2qc4k/sketch_jan20a/sketch_jan20a.ino
2025-01-20T15:01:10.406Z daemon INFO time="2025-01-20T07:01:10-08:00" level=info msg="Checking signature" index=/Users/greg/Library/Arduino15/package_index.json signatureFile=/Users/greg/Library/Arduino15/package_index.json.sig trusted=true
2025-01-20T15:01:10.407Z daemon INFO time="2025-01-20T07:01:10-08:00" level=info msg="Loading hardware from: /Users/greg/Library/Arduino15/packages"
2025-01-20T15:01:10.408Z daemon INFO time="2025-01-20T07:01:10-08:00" level=info msg="Loading package arduino from: /Users/greg/Library/Arduino15/packages/arduino/hardware"
2025-01-20T15:01:10.409Z daemon INFO time="2025-01-20T07:01:10-08:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-01-20T07:01:10-08:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2025-01-20T07:01:10-08:00" level=info msg="Checking existence of 'tools' path: /Users/greg/Library/Arduino15/packages/arduino/tools"
2025-01-20T15:01:10.410Z daemon INFO time="2025-01-20T07:01:10-08:00" level=info msg="Loading tools from dir: /Users/greg/Library/Arduino15/packages/arduino/tools"
2025-01-20T15:01:10.410Z daemon INFO time="2025-01-20T07:01:10-08:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2025-01-20T07:01:10-08:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2025-01-20T07:01:10-08:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2025-01-20T07:01:10-08:00" level=info msg="Loading package builtin from: /Users/greg/Library/Arduino15/packages/builtin"
time="2025-01-20T07:01:10-08:00" level=info msg="Checking existence of 'tools' path: /Users/greg/Library/Arduino15/packages/builtin/tools"
time="2025-01-20T07:01:10-08:00" level=info msg="Loading tools from dir: /Users/greg/Library/Arduino15/packages/builtin/tools"
2025-01-20T15:01:10.410Z daemon INFO time="2025-01-20T07:01:10-08:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2025-01-20T07:01:10-08:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2025-01-20T07:01:10-08:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2025-01-20T07:01:10-08:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
2025-01-20T15:01:10.411Z daemon INFO time="2025-01-20T07:01:10-08:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2025-01-20T15:01:10.413Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.BLTH","label":"/dev/cu.BLTH","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-01-20T15:01:10.414Z discovery-log INFO {"eventType":"remove","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.Bluetooth-Incoming-Port","label":"/dev/cu.Bluetooth-Incoming-Port","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-01-20T15:01:10.414Z daemon INFO time="2025-01-20T07:01:10-08:00" level=info msg="Discovery event channel closed builtin:serial-discovery. Exiting goroutine."
time="2025-01-20T07:01:10-08:00" level=info msg="Closed and removed discovery builtin:serial-discovery"
time="2025-01-20T07:01:10-08:00" level=error msg="Stopped decode loop: EOF" discovery="builtin:serial-discovery"
2025-01-20T15:01:10.415Z daemon INFO time="2025-01-20T07:01:10-08:00" level=error msg="Stopped decode loop: EOF" discovery="builtin:mdns-discovery"
time="2025-01-20T07:01:10-08:00" level=info msg="Closed and removed discovery builtin:mdns-discovery"
2025-01-20T15:01:10.415Z daemon INFO time="2025-01-20T07:01:10-08:00" level=info msg="Discovery event channel closed builtin:mdns-discovery. Exiting goroutine."
2025-01-20T15:01:10.427Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.BLTH","label":"/dev/cu.BLTH","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-01-20T15:01:10.427Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.Bluetooth-Incoming-Port","label":"/dev/cu.Bluetooth-Incoming-Port","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-01-20T15:01:10.437Z daemon INFO time="2025-01-20T07:01:10-08:00" level=info msg="Adding libraries dir" dir=/Users/greg/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries isSingleLibrary=false location=platform
2025-01-20T15:01:10.437Z daemon INFO time="2025-01-20T07:01:10-08:00" level=info msg="Loading libraries index file" index=/Users/greg/Library/Arduino15/library_index.json
2025-01-20T15:01:10.675Z daemon INFO time="2025-01-20T07:01:10-08:00" level=info msg="Adding libraries dir" dir=/Users/greg/Library/Arduino15/libraries isSingleLibrary=false location=ide
time="2025-01-20T07:01:10-08:00" level=info msg="Adding libraries dir" dir=/Users/greg/Documents/Arduino/libraries isSingleLibrary=false location=user
