Serial Port not found after temporarily disabling ModemManager
Hello!
I'm very new to Arduino, my apologies if I don't understand something simple.
I'm on Ubuntu 18.04 trying to connect an ATMEGA32U4 board.
Downloaded the IDE, got permissions to ttyACM0, and ran into this error:
avrdude: Error: butterfly programmer uses avr_write_page() but does not provide a cmd() method.
To fix this problem I tried this: avrdude butterfly programmer uses avr_write_page() but does not provide a cmd() - Avrdude, stk500, Bootloader issues - Arduino Forum
Basically I tried to disable ModemManager:
sudo systemctl stop ModemManager.service
And to check:
systemctl status ModemManager.service
It had worked, but now IDE doesn't find that port. Dmesg --follow showed that I had disconnected the device.
Restarting didn't work, reconnecting didn't work (dmesg didn't even recognize that something had been plugged in).
Tried to connect it while in a VM, the ttyACM0 didn't show up in /dev and Arduino didn't find anything.
Thank you! :slight_smile:
I'm no longer a Linux person
What does below return after a reboot
Did you try
sudo systemctl start ModemManager.service
What is "butterfly programmer"?
I use Linux Mint all the time without problems though I admit I have not tried uploading to my Leonardo for a considerable time.
...R
The butterfly programmer is part of avrdude.
sterretje:
Will it come into play when I upload to an Uno or Mega - because if so it has never caused me a problem. I'm using IDE 1.8.6
...R
To my knowledge, not.
Output of an upload to a Leonardo ( under Windows :wink: )
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM6 -b57600 -D -Uflash:w:C:\Users\sterretje\AppData\Local\Temp\arduino_build_426630/sketch_nov01b.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM6
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         [b]Programmer Type : [color=red]butterfly[/color][/b]
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
    Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
    Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% -0.00s
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: reading input file "C:\Users\sterretje\AppData\Local\Temp\arduino_build_426630/sketch_nov01b.ino.hex"
avrdude: writing flash (7056 bytes):
Writing | ################################################## | 100% 0.56s
avrdude: 7056 bytes of flash written
avrdude: verifying flash memory against C:\Users\sterretje\AppData\Local\Temp\arduino_build_426630/sketch_nov01b.ino.hex:
avrdude: load data flash data from input file C:\Users\sterretje\AppData\Local\Temp\arduino_build_426630/sketch_nov01b.ino.hex:
avrdude: input file C:\Users\sterretje\AppData\Local\Temp\arduino_build_426630/sketch_nov01b.ino.hex contains 7056 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.07s
avrdude: verifying ...
avrdude: 7056 bytes of flash verified
avrdude done.  Thank you.
I was sufficiently intrigued to dig out my Leonardo and try uploading a program to it. It worked first time.
...R
