Serial Port not working on mac, not a counterfeit Arduino Uno
I have been looking all over the internet for answers. At first I downloaded the drivers for the FDT, CH43, etc. It's still not working. An according to the arduino book, all I had to do was install the ide and plug the arduino in and I should see the port, but I do not. image attached. My pic of the arduino is to large to show.
Please READ THIS POST to help you get the best out of the forum.
SIMPLE TROUBLESHOOTING.
These steps may also save you some unnecessary time and effort in the forum.
COMMON ISSUES
  • Check you have a COMMON GROUND where required.
  • Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
  • Try other computers where possible.
  • Try other USB leads where possible.
  • You may not have the correct driver installed. CH340/341 or CP2102
  • There may be a problem with the board check your wiring first.
  • Remove any items connected to pins 0 and 1.
    COMPUTER RELATED
  • Ensure you turn off any additional security / antivirus just to test.
  • There may be a problem with the PC try RESTARTING it.
  • You may be selecting the wrong COM port.
  • Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
  • Clear your browsers CACHE.
  • Close the IDE before using any other serial programs.
  • Preferably install IDE's as ADMINISTRATOR or your OS equivalent
    Performing the above actions may help resolve your problem without further help.
Bob.
It was the cable. I didn't have it push all the way in for the arduino uno. I had to push it where I heard a click sound :). Also, the port names are different for MAC. It was the serial port /dev/cu.usbmodem1411. I hope this helps someone.
