Serial Port Problem
Hello, I have an arduino mega 2560 and i want to set the value of brightness of a led using an application written with Qt which communicates with the arduino through the serial port (USB). The problem is that: the value of the serial port is always 255. When i try to change the value with the Qt widget, it changes... but the next loop it returns to 255.
Can you tell me why i have this problem? The sketch is that
const int ledPin = A15; // the pin that the LED is attached to
byte brightness;
// initialize the serial communication:
// initialize the ledPin as an output:
pinMode(ledPin, OUTPUT);
  // read the most recent byte (which will be from 0 to 255):
brightness = Serial.read();
Serial.println(brightness);
// set the brightness of the LED:
analogWrite(ledPin, brightness);
Thanks
   if (Serial.available() > 0) {
It works!
Thank You
