serial port problem
I’m a beginner in programming.
I’ve done this project: by http://mc.dfrobot.com.cn/thread-26819-1-1.html Make a Small Measuring Wheel
and it’s good. I want to get the result in the seirial port
code
#include <Wire.h>
#include “DFRobot_RGBLCD.h”
DFRobot_RGBLCD lcd(0x7c >> 1, 0xc0 >> 1, 16, 2);
//rgb_lcd lcd;
#define A 3
#define B 4
#define Key 12//key
#define D 79 //Diameter 79mm
float C = 0; //perimeter
unsigned int Distance;
int VA = 0;
int VB = 0;
unsigned long Count = 0;//count
unsigned int Count_1 = 0; //Negative count
unsigned char flag = 1, Mark = 0;
unsigned long lasttime = 0, Modetime = 0;
//Length measurement range is ± 6 M
lcd.init();
lcd.setRGB(255, 255,0);
lcd.setCursor(2, 0 );
lcd.print(“M:”);
lcd.setCursor(2, 1 );
lcd.print(“D:”);
lcd.setCursor(12, 1 );
lcd.print(“cm”);
pinMode(A, INPUT_PULLUP); //Pull-up input
pinMode(B, INPUT_PULLUP);
pinMode(Key, INPUT);
attachInterrupt(1, interrupt, RISING);
C = D * PI;
if (millis() - 150 > lasttime)//Detect keys once every 150ms
if (digitalRead(Key) == HIGH)
Mark += 1;
if (Mark > 2)
Mark = 0;
while (digitalRead(Key) == HIGH);
lasttime = millis();
if (millis() - 100 > Modetime)//Refresh the data every 100ms
if (Mark == 0) //Cleared
lcd.setCursor(6, 0 );
lcd.print("Reset “);
Distance = C * Count / 40;
flag = 3;
lcd.setCursor(11, 0 );
lcd.print(” ");
if (Mark == 1) //Calculate the measured value
lcd.print(“Detection”);//
lcd.setCursor(4, 1 );
if (Count > 0 && Count < 0xffff)//Determine whether the length is positive
lcd.print(’-’);//The length is negative
else if (Count == 0 && Count_1 == 0 )//Determine whether the length is zero
lcd.print(’ ');
else//Length is positive
lcd.print(’+’);
Distance = Count_1 * C / 40;
else if (Mark == 2) //lock
lcd.print("Lock ");
Count = 0;
Count_1 = 0;
Modetime = millis();
lcd.setCursor(5, 1 );//Displays the value of Distance
lcd.print(Distance / 10000);
lcd.print((Distance / 1000) % 10);
lcd.print((Distance / 100) % 10);
lcd.print(’.’);
lcd.print((Distance / 10) % 10);
lcd.print(Distance % 10);
void interrupt()//Interrupt handler
VB = digitalRead(B);
if (Mark == 1)//Detects whether the current mode is a measurement
if (VB == 1)//To determine whether the positive measurement
flag = 1;
if (Count > 0xffff)
Count_1 -= 1;
Count += 1;
else//Reverse measurement
flag = 0;
Count -= 1;
if (Count > 0xFFFF)
Count_1 += 1;
//Count is cleared over the range
if (Count < 0xFFFF && Count > 0x294A)
Count = 0;
else if (Count < 0xFFFFD6B5 && Count > 0xFFFF)
Count = 0;
Go for it!
Towards that goal, you might find these a helpful resource:
