Wow! It was about time I talk about this problem. Thank you so much. I should of though about it, I included this to my *.cpp but not to my *.h. Now byte work. Yeap thank you superfully
No worries, I find myself looking at the core frequently to verify stuff.
@Frédéric_Plante, please do not delete posts. The code I wrote does not make sense without the 'real' if statement. It has little relevance to the 'if' I asked you for more info on.
So if people are wondering where I pulled the values from, here is the code.
if (bit_parite == 0){
if(longueur_donnees == 7){
if (bit_arret == 0){configuration_UART=0x04}
else if (bit_arret == 2){configuration_UART=0x0C}
if(longueur_donnees == 8){
if (bit_arret == 0){configuration_UART=0x06}
else if (bit_arret == 2){configuration_UART=0x0E}
else if (bit_parite == 1){
if (bit_arret == 0){configuration_UART=0x34}
else if (bit_arret == 2){configuration_UART=0x3C}
if (bit_arret == 0){configuration_UART=0x36}
else if (bit_arret == 2){configuration_UART=0x3E}
else if (bit_parite == 2){
if (bit_arret == 0){configuration_UART=0x24}
else if (bit_arret == 2){configuration_UART=0x2C}
if (bit_arret == 0){configuration_UART=0x26}
else if (bit_arret == 2){configuration_UART=0x2E}
