So, until two hours ago everything worked perfectly between Linux Mint (Ubuntu) and Arduino Uno. Then, all of a sudden, the serial port was not found any more by Linux.
So far I have tried, all to no avail:
- Rebooting a few times.
- Connecting while holding Arduino’s reset button (since someone suggested that the Arduino sending too much data through the Serial port might be a problem for Ubuntu).
- Connecting a USB-stick to the USB-port to test it, with no problems.
While things still worked, dmesg for connecting read:
[ 359.852517] usb 3-4: new full speed USB device using xhci_hcd and address 0
[ 359.899964] xhci_hcd 0000:0f:00.0: WARN: short transfer on control ep
[ 359.904000] xhci_hcd 0000:0f:00.0: WARN: Stalled endpoint
[ 359.905991] xhci_hcd 0000:0f:00.0: WARN: Stalled endpoint
[ 359.907999] xhci_hcd 0000:0f:00.0: WARN: Stalled endpoint
[ 359.909969] xhci_hcd 0000:0f:00.0: WARN: Stalled endpoint
[ 359.911996] xhci_hcd 0000:0f:00.0: WARN: Stalled endpoint
[ 359.914037] xhci_hcd 0000:0f:00.0: WARN: Stalled endpoint
[ 359.922033] xhci_hcd 0000:0f:00.0: WARN: short transfer on control ep
[ 359.930989] xhci_hcd 0000:0f:00.0: WARN: short transfer on control ep
[ 359.933195] usb 3-4: ep 0x82 - rounding interval to 1024 microframes, ep desc says 2040 microframes
[ 359.981193] cdc_acm 3-4:1.0: ttyACM0: USB ACM device
[ 359.986115] usbcore: registered new interface driver cdc_acm
[ 359.986119] cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
Now, it only says:
[ 1448.477731] usb 3-4: new full speed USB device using xhci_hcd and address 0
[ 1448.514765] xhci_hcd 0000:0f:00.0: WARN: short transfer on control ep
[ 1448.518760] xhci_hcd 0000:0f:00.0: WARN: Stalled endpoint
[ 1448.520759] xhci_hcd 0000:0f:00.0: WARN: Stalled endpoint
[ 1448.522757] xhci_hcd 0000:0f:00.0: WARN: Stalled endpoint
[ 1448.524756] xhci_hcd 0000:0f:00.0: WARN: Stalled endpoint
[ 1448.526717] xhci_hcd 0000:0f:00.0: WARN: Stalled endpoint
[ 1448.528793] xhci_hcd 0000:0f:00.0: WARN: Stalled endpoint
What else can I try?
– Shir Khan
