Today I am working on a Chinese Nano clone. This started out as a quick programming exercise to count loops in a second to practice using the attached RTC. I sorted that out, and decided to add a millis timer to see how far away from a second the code varied. This took a few hours, as I am less than a proficient coder! (hence the practice project ) In any case, my issue for the past few hours has been trying to get the difference in elapsed time to print in the serial monitor and I have been unsuccessful in finding an answerto why I only get a zero, when plainly the difference is ~1000mS. Below is the code I am using.
* Demonstrates timing.counting with RTC
* seconds field. Since seconds are so long
* in microprocessor time, it is imperative
* to begin timing at a known point after
* the seconds field changes. In this program,
* the loop is completed 939 (usually) in one
* second on the RTC. This does not account for
* data fetch from the RTC, print and could vary in
* time to complete the loop.
* A millis counter was included as an after
* thought, but consumes additional cycles to
* calculate and print the values,adding error time.
* Currently,
* I cannot get a difference in millis to print.
* and I am lost in rabbit hole after rabbit hole!
* It should be 1000, but I only get 0.
#include "Arduino.h"
#include <math.h>
#include <Wire.h>
#include "RTClib.h"
//pin A4 SDA
//pin A5 SCL
int loopCounter = 0;
int printCounter = 0; //to avoid repeatedly printing time
int sec = 0;Â //seconds
int lastSec = 0;
int firstSec = 0;
unsigned long startMillis = 0;
unsigned long endMillis = 0;
unsigned long elapsedMillis = 0;
DateTime now;
RTC_DS1307 rtc;
 rtc.begin();
 if (!rtc.begin()) {
  Serial.println("Couldn't find RTC");
  while (1);
Â
 Serial.println("FinishedSetup");
 now = rtc.now();
 firstSec = now.second();
}//end setup
 now = rtc.now();
 sec = now.second();
 if (sec > firstSec) {
  startMillis = millis();
  lastSec = sec;
  //Serial.println("DEBUG1");
  loopCounter++;
  if (printCounter < 1) {
   Serial.print(startMillis);
   Serial.println(" startMillis");
   printTime();
   printCounter ++;
 if (lastSec == (firstSec + 2)) {
  endMillis = millis();
  Serial.print(endMillis);
  Serial.println(" endMillis");
  printTime();
  elapsedMillis = endMillis - startMillis;
  Serial.print(elapsedMillis);
  Serial.println(" elapsedMillis");
  Serial.print(loopCounter);
  Serial.println(" loops in an RTC second");
  while (1);
}//end loop
void printTime() {
 if (now.hour() < 10)
  Serial.print("0");
 Serial.print(now.hour());
 Serial.print(':');
 if (now.minute() < 10)
  Serial.print("0");
 Serial.print(now.minute());
 Serial.print(':');
 if (now.second() < 10)
  Serial.print("0");
 Serial.println(now.second());
Any help would be greatly appreciated!
Cheers,
-fab
fabelizer:
int sec = 0; //seconds
int lastSec = 0;
int firstSec = 0;
DateTime now;
RTC_DS1307 rtc;
rtc.begin();
if (!rtc.begin()) {
while (1);
now = rtc.now();
Idaho:
Thanks, but didn't change anything. The initialization to zero is just as effective.
Paul:
I got prints of the seconds as expected. But this is not part of the problem. The serial output shows the 1st sec as 48, the sec as 49, and ends at 50...as expected. That would change according to the time the program starts, but is only related to the RTC. Not much to do with millis().
In fact, I think this might be a quirk in the print function. It either refuses the unsigned long, or for some reason can't deal with it. Unfortunately, I still have not figured it out. The Arduino reference page show no such restriction, but then there is no UL example either. All references I have found in the forum do not deal with printing, only that the elapsed time is simply an arithmetic subtraction. That part I had already!
I have also tried just using "millis()" in the subraction to eliminate the endMillis variable....no help. (lot's of other things too...too many to mention! Always with the result that the elapsedMillis variable get printed as 0.
I am attaching a printed screen for reference, this is after I returned to the original code posted:
Serial.println( endMillis );
Serial.println( startMillis );
if (sec > firstSec){ will be executed more than once, so the value of startMillis will continue to rise. You don't see that in the serial monitor because printCounter has become 1 (one).
Later on, when if (lastSec == (firstSec + 2)){ becomes true, you substract startMillis from endMillis, but since startMillis has become larger than endMillis, the result will be negative. Which is impossible, because it's an unsigned long integer.
Add two lines to this code:
  Serial.print(startMillis);    // <= added line 1
  Serial.println(" startMillis"); // <= added line 2
to see if I'm right. I hope so, I didn't check it...
Erik_Baas:
Almost correct, except that startMillis will not be larger than endMillis, but either the same or a bit less, depending on when the interrupt for the millis counter occurs. A 'negative' result on unsigned arithmetic would cause a very large positive number, not 0.
Did the add, and THANKS! that appears to be the problem!!
Of course it printed correctly when I captured it, but as you said, it adds to same as other! See....that's why I practice coded today! I never would've noticed!
FinishedSetup
82 startMillis
20:44:01
1083 endMillis
20:44:02
1001 elapsedMillis
939 loops in an RTC second
FinishedSetup
731 startMillis
20:44:14
1730 endMillis
20:44:15
999 elapsedMillis
938 loops in an RTC second
FinishedSetup
26 startMillis
20:44:23
1027 endMillis
20:44:24
1001 elapsedMillis
FinishedSetup
924 startMillis
20:44:33
1924 endMillis
20:44:34
1000 elapsedMillis
* the loop is completed 939 times. (usually) in one
* data fetch from the RTC, prints, etc. and could
* vary in time to complete the loop.
* calculate and print the values, increasing error time,
* but providing a finer grain of execution time.
* Thanks to Idahowalker, Erik_Baas, and david_2018
* for helping me sort out my error.
#include <math.h>
#include <Wire.h>
#include "RTClib.h"
//pin A4 SDA
//pin A5 SCL
int lastSec = 0;
int firstSec = 0;
DateTime now;
RTC_DS1307 rtc;
 rtc.begin();
 if (!rtc.begin()) {
  while (1);
Â
 now = rtc.now();
 //Serial.println(firstSec);
}//end setup
 now = rtc.now();
 sec = now.second();
 //Serial.println(sec);
  if(startMillis == 0){
  lastSec = sec;
  loopCounter++;
   printTime();
   printCounter ++;
  //Serial.print(startMillis);    // <= added line 1
  //Serial.println(" startMillis"); // <= added line 2
  printTime();
  while (1);
}//end loop
void printTime() {
  Serial.print("0");
 Â
 Serial.print(':');
  Serial.print("0");
 Serial.print(':');
  Serial.print("0");
Posted patched up code and included screen print with 3 resets for posterity!
Thanks again!
-fab
