Serial.print and interrupts problem
Hi to everyone. I am making a project (Hard Drive POV clock) in wich I need to read te RPM (or the time each revolution takes) of a hard drive using a magnet and a hall effect sensor. I have the hardware and the code up and running but I noticed that when I use Serial.println to print values, others values changes... and I don't know why. Here is the code and an example to explain it better
volatile unsigned long vueltas = 0;
float tiempoVuelta = 0;
unsigned long tiempoAnterior = 0;
  attachInterrupt(0, rpm_fun, FALLING); //interrupt 0 -> pin 2
void rpm_fun() // INTERRUPTION
  vueltas++;
void cuentavueltas() // tiempoVuelta = time of each revolution
  if(vueltas>=1)
    tiempoVuelta = (micros()- tiempoAnterior)/ vueltas;
    tiempoAnterior = micros();
    vueltas=0;
    Serial.print("Total: ");
    Serial.println(tiempoVuelta/12);
    Serial.print("Division: ");
    Serial.println((tiempoVuelta/12)*0.02);
    Serial.print("Espacio: ");
    Serial.println((tiempoVuelta/12)*0.98);
  return;
I read: Total: 707.17 Division: 14.14 Espacio: 693.02
But if I comment some Serial.print lines:
if(vueltas>=1)
    vueltas=0;
//    Serial.print("Division: ");
//    Serial.println((tiempoVuelta/12)*0.02);
//    Serial.print("Espacio: ");
//    Serial.println((tiempoVuelta/12)*0.98);
I read Total: 648.33
Wich is the correct value for tiempoVuelta/12 ?? And why I am getting that difference? Is it because of the time it takes to print the values to the serial monitor? Waht would be a better way to do this? The disc is spinning at 7200 rpm.
Thank you very much!
Basic rule with serial: Divide BPS by 10 gives how bytes per sec, divide this into 1 and that is how long it takes to send a byte... EG 9600bps = 960 into 1 = approx 0.001sec to send 1 byte Your "tick" is 7200/60 into 1 = 0.009sec Suggest to start with, change serial to as high as you can go (115k?) this will give you more time between data being sent to next tick
jamesvote: Basic rule with serial: Divide BPS by 10 gives how bytes per sec, divide this into 1 and that is how long it takes to send a byte... EG 9600bps = 960 into 1 = approx 0.001sec to send 1 byte Your "tick" is 7200/60 into 1 = 0.009sec Suggest to start with, change serial to as high as you can go (115k?) this will give you more time between data being sent to next tick
Hey thanks for answering! I really didn't know that about Serial.println, definitely I'm going to check it out and give it a try.
Thanks again!
