Serial.print and Servo's
I’m simply trying to print the servo’s POT position to the monitor, but when I add Serial.print to the code… the servo (motor) stops working?!
The code is straight from the MegaServo download…
#include <MegaServo.h>
#define NBR_SERVOS 1  // the number of servos, up to 48 for Mega, 12 for other boards
#define FIRST_SERVO_PIN 0
MegaServo Servos[NBR_SERVOS] ; // max servos is 48 for mega, 12 for other boards
int pos = 0;      // variable to store the servo position
int potPin = 0;   // connect a pot to this pin.
  // Serial.begin(19200);
  for( int i =0; i < NBR_SERVOS; i++)
    Servos[i].attach( FIRST_SERVO_PIN +i, 800, 2200);
  // Serial.print("setup complete");
  pos = analogRead(potPin);   // read a value from 0 to 1023
  for( int i =0; i <NBR_SERVOS; i++) {
   // Serial.print(i);
    Servos[i].write( map(pos, 0,1023,0,180));
  delay(15);   }
Uncommenting the Serial.begin kills the servo. Using either 9600 or 19200…
Thanks for any help!
S.
Right there.
Move the servo to a pin that isn’t being used to perform serial communication, and all should be fine.
many thanks!
S.
