Hello,
I'm using Serial.print() to debug my program (see where it runs and where it does not). Currently the program is supposed to print out the following:
"Starting...."
then
"IMU Started"
then
"MLB"
then
"Roll Loop Done"
However, in the Serial Consol, I'm getting these phrases cut off at random sections like this:
"Starting....IMU StartedMLBRollLo"
Why is this?
Thanks,
Zachary
It's not the while loop timer issue. I tried while(1) and it did the same thing. One thing to note is that "MLB" is always complete. I'll upload the files I'm working with. It isn't the complete package, so it won't compile, but it should be all that is necessary.
void Plane::Move(int roll, int pitch, int yaw, String velocity, int time) /// time in miliseconds
desiredRoll = roll;
desiredPitch = pitch;
desiredYaw = yaw;
desiredVelocity = velocity;
unsigned long startTimer = micros();
unsigned long endTimer = micros();
while ((endTimer - startTimer) < (time*1000)) {
Serial.println("MLB");
delay(15);
rollPlane(roll);
Serial.println("Roll Loop Done");
delay(15);
pitchPlane(pitch);
Serial.println("Pitch Loop Done");
yawPlane(yaw);
Serial.println("Yaw Loop Done");
velocityPlane(velocity);
Serial.println("Velocity Loop Done");
/// May need a function to check if there is a lost connection/regained conection to the IMU via Serial
plane_v5.ino (670 Bytes)
AutoCorrect.cpp (7.44 KB)
MiniTasks.cpp (10.7 KB)
Plane.h (3.02 KB)
