Serial.Print() delayed
Hi
I have a simple sketch (see) below;
Serial.begin(19200);
Serial.setTimeout(10);
// while(!Serial){
delay(10000); //Take some time to open up the Serial Monitor
int x = 0;
while(x < 10) {
Serial.print(“Startup!!!”);
Serial.println(String(x));
++x;
Serial.flush();
when I run this with the Serial monitor open I get no output for over ten seconds and then all ten lines appear at once.
I have tried different baud rates and a different serial monitor but no joy?
Can anybody help please?
GordonNorris:
That seems to be what you programmed. What do you want it to do?
This is silly
because the business of opening the Serial Monitor will cause the program to restart which means, in practice, that the Serial Monitor was already open before the program got to this line.
...R
GordonNorris:
If you want to delay BETWEEN messages you have to put the delay between messages:
  // Serial.setTimeout(10);  // Only used for input
  // This is equivalent to your: "int x=0; while(x<10){... ++x;}" but easier to read
  for (int x = 0; x < 10; x++)
    delay(1000); // delay one second
    Serial.print("Startup!!! ");
    Serial.println(x);  // No need to convert an integer to a String to print it.
  Serial.flush();  // Not needed.  The serial buffer will empty pretty quickly.
