serial.print(); doesnt work
Hi, as the title says Serial.print () does not work on my Arduino UNO.
More specifically the trouble is usually it works, but when I run the following code not:
#include <MemoryFree.h>
#include <wolfssl.h>
#include <wolfssl/wolfcrypt/sha256.h>
unsigned long inicio;
unsigned long tiempo;
  while(!Serial);
  byte shaSum[SHA256_DIGEST_SIZE];
  byte buffer[1024] = {"hola mundohola mundohola mundoho"};      // fill buffer with data to hash
  Sha256 sha;
  inicio = micros();
  wc_InitSha256(&sha);
  wc_Sha256Update(&sha, buffer, sizeof(buffer));  // can be called again and again
  wc_Sha256Final(&sha, shaSum);
  tiempo = micros() - inicio;
  Serial.print("Tiempo sha256: ");
  Serial.println(tiempo);
  delay(3000);
If I comment functions "wc_InitSha256" "wc_Sha256Update" "wc_Sha256Final" Serial.print () works perfectly.
Also if I run the code using an Arduino Mega board everything works smoothly.
Can you give me some solution?
Thank you very much for your time.
You only have 2K of RAM on an Uno for globals and stack, and you've overflowed it.
