Serial print HEX Commands with quotes does not work right
Hello everyone. I would expect that this piece of code:
  Serial.print("\xAA\x62\xFE\x01\x00\x61");
  delay(400);
would print to a serial monitor(with HEX receive enabled) this:
AA 62 FE 01 00 61
AA 62 FE 01 00 61
AA 62 FE 01 00 61
etc...
But it does not. What it does is this:
AA 62 FE 01
AA 62 FE 01
AA 62 FE 01
etc...
It seems that Arduino understands the \x00 as a nothing,maybe? What can i do to solve this? Btw, this is a volume up RS232 command for a Samsung display monitor and Samsung monitors accept this HEX command syntax ONLY : \xAA\x62\xFE\x01\x00\x61
How is the end of a C string indicated?
Try write instead.
Edit: wait. "write" uses strlen . . .
Send the bytes with individual writes
There is a variant with a specified length.
Serial.write(buf, len);
So
Serial.write("\xAA\x62\xFE\x01\x00\x61", 6);
should work.
Thank you both. It worked with both ways.
