I'd like to do this in one line, but doing it as "Serial.print(something . "\t something else" . somethingelse . "\t\n")" doesn't seem to work, same with using + to combine it to the same line. Maybe I'm missing something obvious?
The below is the Streaming example. Doesn’t seem to want to compile.
#include <Streaming.h>
int lettera = 'A';
int month = 4, day = 17, year = 2009;
Serial << "This is an example of the new streaming" << endl;
Serial << "library. This allows you to print variables" << endl;
Serial << "and strings without having to type line after" << endl;
Serial << "line of Serial.print() calls. Examples: " << endl;
Serial << "A is " << lettera << "." << endl;
Serial << "The current date is " << day << "-" << month << "-" << year << "." << endl;
Serial << "You can use modifiers too, for example:" << endl;
Serial << _BYTE(lettera) << " is " << _HEX(lettera) << " in hex. " << endl;
Hard to help you unless you specify the error.
I can tell you that the code in question compiles both on arduino 1.0.3 (openSUSE Linux 12.3) and on ArduinoDroid on my Galaxy S3. It also runs (would be nice to add a _CHAR type).
Do you believe your development environment works correctly? If not, fix that first.
I have caught errors in downloaded code (and the two environments I mentioned differ in what errors they catch). Generally you can expect examples to work.
