Serial print, how to print full array?
Hello,
I'm trying to print the 6 bytes from buffer over to the serial monitor of Arduino, but I'm only getting one byte.
Tried searching the web, but only came up with Serial.write(buffer,6);
With this nothing shows in the serial monitor.
Can somebody give me some hints?
Mega2560 btw...
byte buffer[6];
byte MINUS1[6] =  {0x44,0x06,0x02,0x00,0x02,0xFF}; //example data
byte in[6];
  Serial1.begin(9600);
  Serial1.readBytesUntil(0xFF,buffer,6);
  Serial.println(buffer[6], HEX);
  //Serial.write(MINUS1,6);
  Serial1.flush();
You need a loop for that:
for (int i = 0; i < 6; i++) Serial.print(buffer[i], HEX);
EDIT: “i<=6” should be “i<6” or “i<sizeof(buffer)” :slight_smile:
buffer[6]
that is a pointer to the 7th element of your 6 byte array, or put another way, outside the bounds of your array (which can be addressed at element zero through five).
“i<sizeof(buffer)”
That gives the number of bytes in the array. If the elements are bytes that works. More robust is “i<sizeof(buffer)/sizeof(buffer[0])”. That will return the number of elements independent of the data type,
groundFungus:
That give the number of bytes in the array. If the elements are bytes that works. More robust is “i<sizeof(buffer)/sizeof(buffer[0])”. That will return the number of elements independent of the data type,
Yep, but even better would be a constant / define which declares the size of the array :slight_smile:
If you later change the size of the array you must remember to change the constant.
groundFungus:
If you are dynamically allocating / reallocating an array, you most likely will have a variable with the size of the array - otherwise you would be a nutter! :wink:
The readBytesUntil function blocks until all the read is complete. Serial data comes in slowly so the processor is tied up while waiting. A non-blocking approach to serial receive is shown in Robin2’s serial input basics thread.
Danois90:
EDIT: "i<=6" should be "i<6" or "i<sizeof(buffer)" :)
Thankyou! :slight_smile:
BulldogLowell:
buffer[6]
WOW, you just blew my mind! I didn’t think of it that way! I thought that it was one continuous string of bytes.
Can I successfully compare buffer with MINUS1? like:
if(buffer == PLUS1){
    digitalWrite(13, HIGH);
It is a continuous array. But the first index is 0 and the last one is 5 (for array size 6).
Snake____1:
No, since that would compare the memory location, not the contents of the arrays. You need a for loop or memcmp for such a compare.
Danois90:
or the standard c string library
strcmp()
strstr()
Danois90:
You guys are magicians! Works like a charm now :slight_smile:
byte buffer[6];
byte PLUS1[6] =   {0x44,0x06,0x04,0x00,0x02,0xFF};
byte in[6];
  pinMode(13, OUTPUT);
  Serial.print(buffer[0], HEX);
  Serial.print(buffer[1], HEX);
  Serial.print(buffer[2], HEX);
  Serial.print(buffer[3], HEX);
  Serial.print(buffer[4], HEX);
  Serial.println(buffer[5], HEX);
  if(memcmp (buffer, PLUS1, sizeof(buffer)) == 0){
  else if(memcmp (buffer, MINUS1, sizeof(buffer)) == 0){
    digitalWrite(13, LOW);
  Serial1.flush();
  buffer[0] = 0x00;
  buffer[1] = 0x00;
  buffer[2] = 0x00;
  buffer[3] = 0x00;
  buffer[4] = 0x00;
  buffer[5] = 0x00;
groundFungus:
The readBytesUntil function blocks until all the read is complete. Serial data comes in slowly so the processor is tied up while waiting. A non-blocking approach to serial receive is shown in Robin2's serial input basics thread.
Might take the serial receive function into consideration later, thanks!
BulldogLowell:
strcmp()
strstr()
Useless in this scenario; No null termination and a buffer which may contain null/zero as a value :slight_smile:
