I am trying to use an HC-05 module to map the bend of a flex sensor (essentially a potentiometer) to a servo position. But when I use the serial monitor, I am not sure why it does not display the mapped integer value. When I remove the Serial.write it seems to work fine, but I need Serial.write to interface with another HC-05 Bluetooth module on another Arduino. I have included the "broken" serial monitor output from bending the flex sensor and then the code below that.
const int flexPin = A0;
int flexValue = 0;
#include <Servo.h>
Servo servoIndex;
int state = 0;
pinMode(flexPin, INPUT);
servoIndex.attach(9);
Serial.begin(38400); // Default communication rate of the Bluetooth module
state = Serial.read(); // Reads the data from the serial port
if (Serial.available() > 0) { // Checks whether data is comming from the serial port
// Reading the potentiometer
flexValue = analogRead(A0);
int flexValueMapped = map(flexValue, 740, 960, 0, 180); // maps flexValue of min 740 max 960 to servo 0-180
int avgFlexValueMapped;
int MeasurementsToAverage = 100;
for (int i = 0; i < MeasurementsToAverage; ++i) // averages last 100 data points to filter and smooth data
avgFlexValueMapped += flexValueMapped;
delay(1);
avgFlexValueMapped /= MeasurementsToAverage;
Serial.println(avgFlexValueMapped);
//ADD A DATA TYPE? ^^^
Serial.write(avgFlexValueMapped); // Sends flexValue to servo motor
//analogWrite(1, flexValueMapped);
servoIndex.write(avgFlexValueMapped);
delay(10);
if (Serial.available() > 0) // Checks whether data is comming from the serial port
What is the point of this ?
This performs integer division. What do you see if you print the 2 values before the calculation ?
Why is avgFlexValueMapped ab int ?
This will be used to receive data from another Arduino in the future. Once I know that data is being received I will turn on an LED; however, it currently serves no function for this code. I apologize for including it.
The MeasurementsToAverage displays this on the serial monitor.
groundFungus:
The default baud rate for communication with HC05 is 9600. 38400 is the default rate for the AT mode.
Hi, would you mind elaborating a bit more? All the examples I've seen online have used 38400. What is the difference between AT mode and the "communication" mode? Thanks so much for your help I really appreciate it!
Serial.write will write only one byte, except when you add a second parameter to tell how much byte it must write.
But in any cases, these bytes are not meant to be printed, they should not be treated as ASCII characters, this is why you see those strange characters in the serial monitor.
This is what you should use if you want to send your int as bytes. If not then just remove this line, and send as ASCII characters with print() or println() as you already did on the previous line..
Communication mode is for when the HC05 is talking to another Bluetooth device (another HC05). AT mode is for setting up the HC05. In AT mode you can set the communication baud rate, change the name, change the pass code and many other things.
What Arduino are you using? I seems that you are using the serial monitor and have the HC05 on hardware serial (USB) at the same time. It is better if you have the HC05 on its own serial port and reserve the hardware serial port for program upload, program output and debugging. If you are using an Uno or Nano I would recommend using a software serial port.
I would constrain the values fed to the map function. Values outside of 740 to 960 will still be mapped and will be outside of the desired 0 to 180.
Here is test code, using software serial, that you can use to verify communication between your Bluetooth device and the HC05.
