serial.Print not working
Why am I not getting the letter "P" on the serial monitor, instead I am getting 80 which is ascii for letter "P" ??
can anybody help.
Thanks
byte ampm;
ampm ='P';
Serial.println(ampm);
Try double quotes?
ampm ="P";
Or char ampm = 'P';
Interesting, three of four methods apparently send the byte representing the "P", and one method sends the decimal representation of the byte representing the "P".
  //char ampm;
  byte ampm;
  ampm ='P';
 Serial.print(ampm);
 //Serial.write(ampm);
Thank your for your suggestions, I changed my code and it works now.
if (ampm ==1)
Serial.print("PM");
Serial.print("AM");
If you maintain a boolean variable true if PM false if AM then you could use the ternary operator.
boolean pm = true;
Serial.print( pm ? "PM" : "AM" ); // will print PM in this case
That is a functional equivalent to :
if (ampm ==1)
    Serial.print("PM");
    Serial.print("AM");
Maybe:
  byte ampm;
  ampm ='P';
 Serial.println( (char) ampm);
