Serial.print not working
hi all
for some reason my Serial print isn’t working at all
there are no errors or mistakes i can see but i’m very now so i’m probably missing some thing obvious
int ledpinr = 5;
int ledping = 6;
int ledpinb = 7;
int trigPin1 = 8;
int echoPin1 = 9;
int red = 255;
int blue = 255;
int green = 255;
int val;
boolean busy = false;
long duration1, distance1;
  pinMode(trigPin1, OUTPUT);
  pinMode(echoPin1, INPUT);
  led_update();
void loop() {}
void led_update()
  //Set PWM on pins 9 10 and 11
  analogWrite(ledpinr, red);
  analogWrite(ledping, green);
  analogWrite(ledpinb, blue);
  //delay(500);
void color_morph(int* value, int maxval, int get_brighter)
  if (maxval > 255) {
    maxval = 255;
  else if (maxval < 0) {
    maxval = 0;
  for (int i = 0; i < maxval; i++)
    if (get_brighter) {
      if (*value > 0) {
        (*value)--;
    else {
      if (*value < 255) {
        (*value)++;
  led_update();
  delay(5);
  digitalWrite(trigPin1, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin1, HIGH);
  delayMicroseconds(10);
  duration1 = pulseIn(echoPin1, HIGH);
  distance1 = (duration1 / 2) / 29.1;
Serial.print(distance1);
Serial.println("cm");
How are you going to access the functions with the Serial.print statments if you don’t call them in your void loop()
void loop() {}
Nothing is being done.
  if (maxval > 255) {
    maxval = 255;
    maxval = 0;
    if (get_brighter) {
      if (*value > 0) {
        (*value)--;
    else {
      if (*value < 255) {
        (*value)++;
  led_update();
  delay(5);
Here are your Serial.print , but you are not using the function.
The code runs
You have to include the function calls yourself in setup or loop.
Just because you code the functions after the void loop() does not mean they are used.
Tom… :slight_smile:
And … a tip is to ‘serial print (“Go!”);’ just after the serial begin statement. - then you know it’s working and later problems are your fault !!
Don’t forget you can print things as a debugging tool “ program is here” etc
