system
June 29, 2014, 3:04pm
1
Hi.
I'm using Serial.print/ln commands to debug some code.
So here is part of my code:
void timeSyncNode(byte node, char* timeCommand)
Serial.print("command1:"); Serial.println(timeCommand);
Serial.print("command2:"); Serial.println(timeCommand);
Output is OK:
command1:T1234567897
command2:T1234567897
But now if I add another print line between those two outputs (type is byte), then last command's output is wrong:
Serial.print("node:"); Serial.println(node);
Output of 3rd line is wrong:
node:2
command2:T?
Could you guys explain it to me why is this happening ? "command2" output should be same as "command1" ?
can you post the complete code ?
(or minimize the code to an example that shows the problem)
I suspect one of the parameters is not right or you are out of memory.
system
June 29, 2014, 3:32pm
3
I suspect that your string is NOT null-terminated. Therefore, the code is finding a NULL somewhere else, and using that to terminate your string. Pass a properly NULL terminated array to the function.
system
June 29, 2014, 4:08pm
4
PaulS:
This is me being picky but the '\0' string terminator character is called NUL and not NULL. NULL is something else.
system
June 29, 2014, 4:17pm
5
Thank you all for your replies.
Ok here is now I call timeSyncNode function:
char* timeSyncMessage()
time_t t = now();
char buf[88];
snprintf(buf, 16, "%c%lu",TIMEHEADER, t); //TIMEHEADER IS "T". I should get T + 10 digits here
return buf;
#include <RFM69.h>
#include <Time.h>
RFM69 radio;
byte nodeId = radio.SENDERID;
char* time = timeSyncMessage();
timeSyncNode(nodeId,time);
system
June 29, 2014, 4:54pm
6
Why is buf allocated on the stack if you're going to return its address?
system
June 29, 2014, 4:58pm
7
bwat:
Now we know why your code doesn't work. You can NOT do this.
system
June 29, 2014, 6:22pm
8
Sorry, I'm little rusty with C.
Could you guys please tell me what's the right way to do it ?
What I want is to return:
"T" + current timestamp, which I get with now() function (time_t type).
Example: T1234567890
Something like:
time_t t = now();
char *buf;
return buf;
system
June 29, 2014, 8:17pm
10
Thanks, that works fine.
Is there any better way to concatenate that "T" char and current time in sec. (time_t type) ?
like this?
static char buf[16];
snprintf(buf, 16, "T%lu", now());
return buf;
system
June 29, 2014, 8:38pm
12
I mean if usage of "snprintf" is the right way to do it ? Otherwise I should probably use strcpy/strcat ?
Thanks for your help.
what does now() returns? an unsigned long?
make a loop and add one digit at the time, probably fastest.
system
June 29, 2014, 8:50pm
14
Function now() (from library Arduino Playground - Time ) returns time_t , which is probably int or long. I'll try to do it with loop.
Thanks again for your help.
