sERIAL PRINT PROBLEM
I have developed own clone of arduino. I have below two set of code.
Serial.println("welcome");
ANd
#include <avr/wdt.h>
// These PinS are use to enable and disable analog MUX
int SO_enable = 5;
int S1_enable = 4;
int S2_enable = 3;
static int Device_ID;
int Status_Out[8];
int Output_Read = 2;
int array[8][3] = {
    0, 0, 0
    0, 0, 1
    0, 1, 0
    0, 1, 1
    1, 0, 0
    1, 0, 1
    1, 1, 0
    1, 1, 1
  wdt_enable(WDTO_8S);
  pinMode(SO_enable, OUTPUT) ;// pin can enable/disable using digital IO 7 of arduino
  pinMode(S1_enable, OUTPUT) ;// pin can enable/disable using digital IO 6 of arduino
  pinMode(S2_enable, OUTPUT) ;// pin can enable/disable using digital IO 5 of arduino
  Serial.println("SO \t S1 \t S2 \t DeviceID");
  int ID_value;
  for (int row = 0; row < 8; row++)
    digitalWrite(SO_enable, array[row][0]);
    digitalWrite(S1_enable, array[row][1]);
    digitalWrite(S2_enable, array[row][2]);
    delay(10);
    Status_Out[row] = digitalRead(Output_Read);
Serial.print(digitalRead(SO_enable));
  Serial.print("\t");
Serial.print(digitalRead(S1_enable));
  Serial.print("\t");
Serial.print(digitalRead(S2_enable));
  Serial.println("\t");
  Device_ID = 1 * Status_Out[7] + 2 * Status_Out[6] + 4 * Status_Out[5] + 8 * Status_Out[4] + 16 * Status_Out[3] + 32 * Status_Out[2] + 64 * Status_Out[1] + 128 * Status_Out[0];
  Serial.println(Device_ID);
  Serial.println(".......................................");
when i upload first code . I get Serial print welcome for 1000ms.
WHen i upload the second code Print statement wont print at all, Print only Welcome.
Can someone suggest what might issue.
I am using atmega 328p-PU
You have been here long enough to know this is not the correct section for your post. Thread locked. You will have to recreate your post in a more appropriate place.
