SERIAL.print problem
I use arduino UNO to sample sensor data. In the process of USB Serial receiving data, under normal circumstances, the single data receiving time is 0.1ms, and timeout = 1ms. But in the process of receiving, some data cannot be received normally within the timeout time. The data is divided into two to three packets, 2-3ms.
Here’ s the code.
#include <Arduino.h>
#ifdef ARDUINO_SAMD_VARIANT_COMPLIANCE
 #define SERIAL SerialUSB
 #define SYS_VOL   3.3
#else
 #define SYS_VOL   5
#endif
float cali_data_xy;
float cali_data_z;
int16_t scale;
#define MODUEL_RANGE           20
#define MODULE_VOL             1.8
#define CALI_BUF_LEN           15
#define CALI_INTERVAL_TIME     250
float cali_buf_xy[CALI_BUF_LEN];
float cali_buf_z[CALI_BUF_LEN];
#define XY_PIN   A0
#define Z_PIN    A1
float deal_cali_buf(float *buf)
   float cali_val = 0;
   for(int i = 0;i < CALI_BUF_LEN;i++)
       cali_val += buf[i];
   cali_val = cali_val/CALI_BUF_LEN;
   return (float)cali_val;
void calibration(void)
   SERIAL.println("Please Place the module horizontally!");
   SERIAL.println("Start calibration........");
   for(int i=0;i<CALI_BUF_LEN;i++)
       cali_buf_xy[i] = analogRead(XY_PIN);;
       cali_buf_z[i] = analogRead(Z_PIN);
       delay(CALI_INTERVAL_TIME);
   cali_data_xy =  deal_cali_buf(cali_buf_xy);
   cali_data_z =  (float)deal_cali_buf(cali_buf_z);
   SERIAL.println("Calibration OK!!");
   scale = (float)1000 / (cali_data_z - cali_data_xy);
   cali_data_z -= (float)980 / scale;
   SERIAL.println(cali_data_xy);
   SERIAL.println(cali_data_z);
   SERIAL.println(scale);
void AccMeasurement(void)
   int16_t val_z = 0;
   val_z = analogRead(Z_PIN);
   val_z -= cali_data_z;
   SERIAL.print(val_z * scale / 1000.0);
   SERIAL.println(" g ");
   SERIAL.println(" ");
   SERIAL.begin(115200);
   analogReadResolution(12);
   #endif
   calibration();
   SERIAL.print("Scale = ");
   AccMeasurement();
(Code tags added by Moderator. Next time please use the </> button on the menu.)
And that’s why you should use code tags when posting code
