Hello all
I'm struggling a bit to get a large number to compile in Serial.print. I have a value which has been declared as unsigned long long (I'm measuring a long process in milliseconds which can run for weeks). If I do Serial.print((long)value), it compiles fine. If I do Serial.print((long long)value) or Serial.print((long long unsigned)value it comes up with the "error: call of overloaded 'print(long long unsigned int)' is ambiguous". Looked for any references to this, without success. I'm using Nick Gammon's Robot Racer example Gammon Forum : Electronics : Microprocessors : Interrupts , but with longer times. Essentially, I'm trying to capture a train of pulses 10mS ON 10mS OFF which might run for several hours, then not re-occur for weeks or months. If anyone has done anything similar or my formatting is wrong or it is simply not possible, I would be grateful to hear. I don't actually need to know how long the individual pulses are, just what the duration of the train is.
Thanks
