Hey everyone,
I'm having a problem with the Serial.print function. When I want to send anything other than a string, an error comes up. For example:
Serial.print("This is a string");
is OK.
Serial.print(10);
comes up with an error message
undefined reference to 'Print::print(int, int)'
I'm using Code::Blocks and not the Arduino IDE because of the ease of handling libraries. All the core libraries are in the program.
int main(){
init();
Serial.begin(19200);
Wire.begin();
while(1){
Serial.print("a");
Serial.print(10);
When printing integers, the second (optional) argument is the base numbering system (BIN, HEX, DEC, etc.). It appears as though Code::Blocks is not recognizing that the 2nd argument is optional. It defaults to DEC, so just supply the 2nd argument.
I tried that. Regardless of what 2nd arguments I enter or what I use as the first argument, an 'undefined reference to ...' error appears. Quite frustrating. Why is it that a character string works, but nothing else?
Does the message change as you try different arguments? If the message always refers to the same function (Print::print(int, int)) then I think the problem is with Code::Blocks.
You might try something like:
int val = 10;
int base = 10;
Serial.print(val, base);
See if that is something the compiler likes.
