Serial.print single byte as DEC
I fill a uint8_t with a numeric value between 1 and 250.
How to get the original numeric value ?
Thanks
uint8_t filledValue;
uint8_t original;
original = filledValue;
filledValue = 35;
// look inn original to see the previous value.
I must be missing what you are asking.
-jim lee
Sorry but I need to explain. I working with LoRa Tx and Rx.
On the sender :
    uint8_t packetNum = 25;
    int sizePacketNum = sizeof(packetNum);
    LoRa.write(packetNum, sizePacketNum);
On receiver:
    uint8_t packetNum;
    while (LoRa.available())
       receivedByte = LoRa.read();
       packetNum = receivedByte;
Here, how to print the original value (25) of packetNum ?
This prints 127 for me. Does it not for you?
  delay(200);
  uint8_t val = 127;
  Serial.print(val);  // This prints 127
  Serial.println(val);  // This prints 127
  int8_t val2 = 127;
  Serial.print(val2);  // This prints 127
  Serial.println(val2);  // This prints 127
void loop() {}
What DOES it print if not 25?
Is this like Serial.write() where you pass the ADDRESS of the buffer and the number of bytes to send? That would be:
LoRa.write(&packetNum, sizePacketNum);
Thanks, you are right. Working fine.
Ciao
I’m surprised the compiler didn’t warn you that you were trying to use a byte as a pointer. Do you have compiler warnings turned up to “All” in Preferences?
