Serial.print strangeness
I'm getting one of those bugs which is making my head hurt.
When I use this code:
  while (true)
        //Serial.print(get_light_level(pin,BASE_LIGHT_LEVEL));
        get_light_level(pin,BASE_LIGHT_LEVEL);
        delay (UNIT_TIME_MS);
bool get_light_level (byte pin,int BASE_LIGHT_LEVEL)
  if (BASE_LIGHT_LEVEL - analogRead(pin) > LIGHT_SENSITIVITY)
    Serial.print("1");
    return true;
    Serial.print("0");
    return false;
the output is correct.
However, when I print in the calling function:
      while (true)
        //get_light_level(pin,BASE_LIGHT_LEVEL);
   // Serial.print("1");
    return true;
    //Serial.print("0");
    return false;
the output is incorrect.
My application is fairly time sensitive but I can't think why I'm getting different results (the above results are completely consistent).
Any ideas?
Because you are printing a "bool" variable and inside the function you are printing something too.
luisilva: Because you are printing a "bool" variable and inside the function you are printing something too.
True but that doesn't explain the different results.
sbaratheon: True but that doesn't explain the different results.
What are these results you speak of? Care to share what the output was that confused you?
Yes it does! It's only a matter of know what do you mean you with strange. If you don't mind of explain what you are getting maybe someone can help you.
BTW, what about:
      while (true)
        if (get_light_level(pin,BASE_LIGHT_LEVEL) == true) {
           Serial.print("1");
        else {
           Serial.print("0");
    return true;
    return false;
what is the result that gives you?
