Hi All
Okey, Im new to the programing stuff.
But I have an Arduino, withe a Groove Base shield on top.
To the Base shield I have a groove Rotary Angle Sensor connected on A0.
Now to my qustion.
I want to Serial.print type1 if the Rotary sensor is between 0 and 200,
and if it is between 201 and 400 the Serial.print "type2"
and so on.
In arduino there is this example:
AnalogReadSerial
Reads an analog input on pin 0, prints the result to the serial monitor.
Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
This example code is in the public domain.
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// print out the value you read:
Serial.println(sensorValue);
delay(1); // delay in between reads for stability
