Serial.print won't print element of array w/o Base specification
So I've found something with Serial.print that strikes me as odd, but I'm not sure if it's a bug or just the way things are intended to work. The short test program below produces the problem. If I define an array of characters, and try to use Serial.print to print the value of an element of that array, it prints nothing unless I specify HEX or DEC base in the Serial.print statement.
Here's the output of the program below:
System Startup, test 01
print without specifying base:
print as hex: 2
print as dec: 2
My question is "Why didn't Serial.print print a 2 at the end of line two above?"
byte const IDX = 1;  // memory array index
char cArray[4];  // array of characters
  Serial.println(F("System Startup, test 01"));
  cArray[IDX] = 2;  // put a value in array
  Serial.print(F("print without specifying base: "));
  Serial.println(cArray[IDX]);
  Serial.print(F("print as hex: "));
  Serial.println(cArray[IDX], HEX);
  Serial.print(F("print as dec: "));
  Serial.println(cArray[IDX], DEC);
What does the value 2 correspond to, in the ASCII table? Without an option second argument, that is the character that is going to be printed. Try making cArray[IDX] 95 instead.
Thank you Delta_G. That makes sense. I guess Serial.print is smarter than I was giving it credit. Thanks!
