Serial.printIn is NOT working for me, what's wrong in this sketch?
Rewriting a code to to effeciency problems, and I cannot get Serial.printIn to work.
Is it because there is stuff I'll be adding at a later date just sitting in there?
// ------LIBRARIES
#include <Scheduler.h>
#include <thermistor.h>
#include <NewPing.h>
// ------ULTRASONIC SENSOR
#define TrigPin 13
#define EchoPin 12
#define MaxDistance 200
//Thermistor Temp(0)
NewPing sonar(TrigPin, EchoPin, MaxDistance);
  Scheduler.startLoop(loop2);
  Scheduler.startLoop(loop3);
  delay(50);
  int uS = sonar.ping();
           Serial.print("Ping: ");
           Serial.print(uS / US_ROUNDTRIP_CM);
           Serial.printIn(" CM");
void loop2() {
void loop3() {
yield();[/code
  Serial.println (F("ready"));
// etc
And now?
AWOL:
// etc
And now?
error: expected constructor, destructor, or type conversion before ';' token
 yield();
exit status 1
'class HardwareSerial' has no member named 'printIn'
Well, do you want println or the error print[color=red]I[/color]n?
Pretty straight forward... Spelling (and case) matterz!
pYro_65:
IT'S SUPPOSED TO BE A L?
I didn't realize that...
pYro_65:
I now get the error
WARNING: library Scheduler claims to run on [sam architecture(s) and may be incompatible with your current board which runs on samd] architecture(s).
C:\Users\TERRAN~1\AppData\Local\Temp\cc7pNMN2.s: Assembler messages:
C:\Users\TERRAN~1\AppData\Local\Temp\cc7pNMN2.s:46: Error: constant value required
exit status 1
Error compiling.
And as for the yield(); error, forgot to close with a bracket :stuck_out_tongue:
I still need help resolving this
ArduinoDogs:
You cannot call a function outside of a function unless it is used to initialize a variable declaration.
Where do you intend yield() to be called, inside loop?
What Arduino board are you using, that error looks? ? ? ? like you have a compatibility problem.
What IDE version?
Thanks.. Tom...... :slight_smile:
